Drag Racing Kindle Racing and Dalcorp Racing
Finally time to hit the track with the mods.
Old Aug 10, 2015 | 10:34 AM
yellow dragon's Avatar
Well its been a few years since i hit the tack. Was chasing a knock issue etc…. Now its all good. Running a 2.6, meth, exhaust no cat, and all the other stuff in the sig. Gonna have to relearn how to launch with the increase in power and torque. I only have my dd tires no slicks or DR's. Cooper zeon ZPT's. Looked at the thread on how to drag cobalts studied it so will try that stuff. Any other advice?
Old Aug 10, 2015 | 02:32 PM
Bluelightning's Avatar
Got Bewst?
Drive it like you stole it
Old Aug 10, 2015 | 03:55 PM
that's the plan
Old Aug 10, 2015 | 05:18 PM
KMO43's Avatar
What's your goal?
Old Aug 10, 2015 | 05:31 PM
Ideally. Low 13's but that will be a challenge on street tires. But in the 13's for sure.
Sl0wbaltSS's Avatar
No breaking axles please.
Old Aug 10, 2015 | 05:56 PM
Got Bewst?
If he breaks an axel he did something terribly wrong
Old Aug 10, 2015 | 06:24 PM
KMO43's Avatar
I'm in for 13.2
Old Aug 10, 2015 | 11:35 PM
Originally Posted by KMO43
I'm in for 13.2
I like this guy!
Old Aug 17, 2015 | 12:04 PM
Well did not go well. Really having issues launching. Spinning and wheel hopping in 1st, spinning in second kept trying to adjust launch Rpm, pedaling etc.., Humidity was near 90%, the track had just had the first 300' scraped! Need to figure out how to launch I know it has mid-low 13's in it. Gotta find me a nice country road and practice launches. Any thoughts, should I preload using the ebrake etc...?
Old Aug 17, 2015 | 12:35 PM
hawkssoccer11's Avatar
you shouldnt have to pre load at all. get your self some trans mounts to help that wheel hop and then get some pee wee footballs or something and put them in your rear springs so the weight stays up front. then also air the front tires down a bit and add some air in the rear. and then you should be good to go. you want to slip the clutch slightly when launching as well.
Old Aug 17, 2015 | 01:03 PM
I got mounts. Will try the footballs i did air down to 25 psi.
Old Aug 17, 2015 | 01:05 PM
hmm and you still had wheel hop? try a motor mount as well. i know the SS/SC they love to wheel hop lol. but yeah my tuner had an SS/SC on a 2.8 pulley with 42#, heat exchanger, intake, exhaust and dp and ran a 13.2 @ 108 with street tires, but he did the football thing
Old Aug 17, 2015 | 01:08 PM
ya my best saturday was 14.7 @ 99 ugh!
Old Aug 17, 2015 | 01:15 PM
Dipped_Cobalt's Avatar
what was the 60ft?
Old Aug 17, 2015 | 01:24 PM
yeah what was your 60ft time??
Old Aug 17, 2015 | 02:05 PM
My best was 2.2
Old Aug 17, 2015 | 02:30 PM
Staged07SS's Avatar
Administrator
Administrator
Stock motor mount is fine.
Better tires, and springs and or footballs in the rear should help a bit.
Old Aug 17, 2015 | 03:19 PM
footballplaya3k's Avatar
2.2 60' isn't that bad, I'm surprised your time was so slow. How's your shifting?
Old Aug 17, 2015 | 04:04 PM
a 2.2 60ft is actually pretty good but what else happened going down the track??
Old Aug 17, 2015 | 04:08 PM
^^ I was gonna say the same thing, look at your previous run. you ran 2.2 60 also...
I think you got other problems...shifting too early?
the 60 isn't that bad to net you a 14.7
Old Aug 17, 2015 | 05:37 PM
I did put in progress springs a couple days before event. Going down the track spinning in second. I do need to work on power shifting for sure. Basically need to relearn my car.
Old Aug 17, 2015 | 07:02 PM
Got Bewst?
I didn't know you ran a decent 60ft like that. My M62 set up which is almost identical to yours I ran a 13.6@105 with a 2.2 60ft. I know conditions weren't good for power but you should have had a lower time than that then with a 2.2.
Old Aug 17, 2015 | 08:41 PM
UltraSilverSS's Avatar
MPH seems right for a low 14. 13s would be around the +/- 105 mph
Old Aug 18, 2015 | 12:16 AM
Got Bewst?
Everyone was running lower trap speeds due to the weather
