Drag Racing Kindle Racing and Dalcorp Racing
First track run = very dissapointed
Old Aug 23, 2008 | 10:47 AM
terry.davis1's Avatar
Went to the track last night. Was nowhere near impressed with my times. I tried all sorts of different launches, but couldn't net a 'decent' time. Considering that these cars are supposed to do mid 14's, and some even low 14's, I was at least expecting around a 14.5-14.6; not even close. Anybody got any advice?
Sorry about the crappy format, only way I could make it look halfway legible
Code:
Run        1          2       3           4          5         6
60'       2.385      2.389    2.429      2.410    2.353     2.347
330'     6.599      6.486    6.608      6.571    6.425     6.460
1/8      9.962      9.774    9.977      9.905    9.715     9.772
mph     71.51     73.45     70.97     72.45    73.42     72.84
1000'   12.894   12.637   12.915   12.809   12.580    12.665
1/4      15.335   15.022   15.347   15.231   14.971    15.076
mph     93.67     95.78     94.15     94.39    95.55      94.81
temp     88*        88*        88*       88*       88*        86*
time     6:00       6:06      6:12       6:39     7:45       7:58
Run         7         8         9           10       11         12
60'        2.350     2.587      2.280      2.388    2.475     2.505
330'      6.523     6.737      6.408      6.554    6.639     6.671
1/8       9.850     10.037    9.735      9.908    9.977     10.012
mph     72.71      73.33     72.26      71.89     72.59     71.81
1000'   12.747    12.905   12.635    12.820    12.879   12.927
1/4      15.160    15.298   15.052    15.242    15.294   15.345
mph     94.68      95.41     94.49      94.39     94.67     94.60
temp     86*        86*        80*         79*        79*        76*
time     8:04        8:13      9:46       10:12     10:23     10:43
Run 12 was against BoostKing, (SS/TC), 13.225@106.56 on 2.121-60'
Old Aug 23, 2008 | 10:49 AM
BriantheLion26's Avatar
Mods? Stock ss/sc?
Old Aug 23, 2008 | 11:16 AM
Bone stock other than Sportline Springs and a B&M STS
Old Aug 23, 2008 | 11:26 AM
DVSk8er's Avatar
its your 60ft times. what are you launching the car at? are you spinning off the line?
Old Aug 23, 2008 | 11:31 AM
NVMYCOBALTSS's Avatar
the first two issues that I see are time inbetween runs for a cool down, and your 60' times. IF you hot lap the car, the temps never come down thus a slower ET and MPH on an 88* day. If you go back any time soon, make sure to pop the hood and allow at least a 45 min cool down from driving in. My best ET's have come from 160*-195* engine temp on a 75ish degree night with low humidity.
Old Aug 23, 2008 | 11:42 AM
I tried launching at around 2500, feathering the clutch the whole way. I gradually lessened my time that I feathered the clutch; some times they would spin pretty hard, but I would always lift and get back on it; hence some of the really bad 60' times. But even on run #9, I had a 2.280 60', but only netted a 15.052
A dirty air filter couldn't hurt me that bad could it? I mean, it's not black, but I'm sure that it needs changed. I've only had the car 2 months, so I don't know when it was changed last.
Kinda off topic:
Anybody that has done the airbox mod, is there a K&N that I can clamp onto the piping??
Old Aug 23, 2008 | 11:44 AM
ralliartist's Avatar
engine temp has nothing to do with it. It's all about your IAT's. You need more practice launching, and take some ice with you so that you can put it on the blower and the intake manifold between runs.
Old Aug 23, 2008 | 11:45 AM
JimzSS's Avatar
Kinda off topic:
AEM dryflow part #21-2110dk, i know its not k&n, but wont throw a cel.
Old Aug 23, 2008 | 11:47 AM
You do want the engine up to at least 150° to get maximum timing. Besides that, yeah it doesn't really have much to do with it.
Work on getting a 2.2 60', good 1-2 and 2-3 shifts, and cool the car down good in between and you will see 14s.
Old Aug 23, 2008 | 11:51 AM
an0malous's Avatar
his launches actually arent bad at all.
2.3s arent uncommon with stock ss/scs
and he has a 2.2 in there.
im shocked none of you noticed, look at his trap speeds.
those are WAY low.
do you shut your car down between runs and push it through the staging?
are you letting it cool after every 3 runs or so?
Old Aug 23, 2008 | 11:52 AM
BlurpleSS's Avatar
14.9 on a bone stock SS/SC is pretty decent. just work on getting your launch down & you should see some lower numbers. Take some time to let the motor cool down between runs. heat soak will kill you.
those are WAY low.
around 95 is pretty standard for stock in the summer. OP, Try again when it gets colder, i bet you'll get that 14.5 you want.
Old Aug 23, 2008 | 11:53 AM
those are WAY low.
I did notice that just didn't say anything. I would think a bone stock ss/sc should trap atleast high 90s almost 100.
Old Aug 23, 2008 | 11:54 AM
BlurpleSS's Avatar
Kinda off topic:
you gotta slip the clutch a bit otherwise you will get a bit of wheel spin. try launching at 2k too.
not in the hottest part of the year me thinks.
JimzSS's Avatar
Are you going through the traps in 3rd? Is it hitting the rev limiter around there?
Old Aug 23, 2008 | 11:58 AM
an0malous's Avatar
a properly cooled down stock cobalt ss should have no problem trapping in the high 90s even in 80* weather.
i would be willing to bet his car is heatsoaked to hell on every one of those runs, which would explain the low traps
Old Aug 23, 2008 | 11:59 AM
i would be willing to bet his car is heatsoaked to hell on every one of those runs though.
I would have to agree with you one that one Anom. I'd like to know the time difference between each run to see how long the car sat.
Old Aug 23, 2008 | 12:28 PM
impalaboy327's Avatar
Look at the bottom, i believe he puts the time he made the runs, He had as little as 6 minutes between his runs. To many runs in one night brother.
Old Aug 23, 2008 | 12:36 PM
BlurpleSS's Avatar
agreed. You probably got better at driving throughout the night but because of heat soak you ran the same times.
Old Aug 23, 2008 | 06:18 PM
i did stop after run 4 and sat for an hour, and then after around run 8 or 9, the times i posted should tell. im not new to racing, ive probably got close to 300 passes in many different vehicles, but this is the first f/i car and the first stick. i know i was heatsoacking alot at points, and thats when i stopped. i didnt even think about ice. the traps seemed high for the ET, considering the heat, so i was making power. i didnt push the car bc the track was so slow that i only had to have it running for a min or two before i could make my run. no burnouts but did dust them off at times, no water. 40 psi in rear tires, 22 in front (too low?) 1/2 tank of 93 octane (all i ever run in car)
Old Aug 23, 2008 | 08:03 PM
an0malous's Avatar
sounds to me like you have a good working knowledge of running the car at a track.
and your driving isnt to bad at all from what i can see.
it will improve with time in the seat, these are by no means an easy car to launch.
get yourself some monitoring devices to keep an eye on your knock, IAT2 temps, timing advance
and then get some cooling mods and watch the massive difference it will make to those parameters
heres a hint, if your IAT2 is over 147, you will start pulling timing, if its over 160, your pulling ALOT.
generally without cooling, on a hot day, these cars will START a run over 140* and end at some pretty scary numbers.
not only does this put alot of risk on your engine, its robbing massive amounts of power.
at the track, if my IAT2 is over 100* when i begin my pass, it will be my last.
and the car will be parked for a minimum of 30-45 minutes.
Old Aug 23, 2008 | 08:15 PM
I park the car with the hood up for an hour after every pass. I have to, the slicks take a huge toll on the clutch.
Old Aug 23, 2008 | 08:30 PM
sounds like i need an interceptor gauge....
Old Aug 23, 2008 | 10:58 PM
Dayn's Avatar
Ice on very hot aluminium is not the best idea. If there is a strip you can drive back and forth at decent speed with low rpm to get air that will cool you off the fastest. Otherwise pop your hood and sit as long as possible.
Get stage 2. It really is crazy what kind of a difference it makes. Lots more torque for better acceleration and a higher trap. If you don't have the money for that then go with cooling mods. Just don't expect a better 60' with stage 2. I would buy tires but I am broke as hell and really have no use for a 2nd set other than running at a track. So stage 2 + cooling was my personal agenda.
This guy understands. Best mod for track is a set of tires. After tires then get cooling mods then stage 2. Or stage 2 then cooling mods. At the track heat soak and launching is a huge factor so if you only care about drag racing then tires+cooling mods help the most. On the street most races will be from a roll (usually) so stage 2 then cooling mods help more.
Old Aug 24, 2008 | 10:28 AM
If I'm going for a cooling mod...what would be the first thing to pick up?? The second?? I'm not planning on racing this thing a whole lot, since I did that with my last car and killed two transmissions (they were junk to begin with). Can't beat up my daily driver.
$43.95 seem like a good price?? I can get it from Jegs, and since I'm local, I can pick up
Last edited by terry.davis1; Aug 24, 2008 at 10:28 AM. Reason: Automerged Doublepost
Old Aug 24, 2008 | 10:34 AM
boostking's Avatar
hey bro- nice to see you on the forum. ice for the win. I got my best times out of my ss/sc when I went from idle. I would net 2.2 60's all day and low 14's. you MUST let the car cool. wait until the end of the year when its cool. you will see your times come down. I would start your mods off with the dual pass end plate option B and a new heat exchanger. good luck
