Going 11's on the 25th stock internal BLOWERED lsj
no i would need lnf hubs as well. i do have a spare DSS axle, and since the axles are the same if i break one i do have a spare. All you really have to do is preload the drivetrain and not shock your axles and they are fine. Ive done this since day one and have 75k on my axles with no play in the joints
no i use the ebrake to heat my slicks. When i get to the tree i always light first, then while holding the brake pedal let the clutch out some until i feel the slack taken up. release brake and wait for green
Does your track let you run in the grooves? Thats something I wish our track would let us do. Unless its one of their competition weekends, no one gets to run in the prepped grooves.
hell yea i run in the grooves. i has torque steer so bad i have to hang onto the steering wheel lol. and thanks guys. Ralli i still get a small bog when i hook and go even from 5.5k rpms. Im thinking about holding her on limiter and letting her rip
. hopefully i wont leave my trans at the tree considering i sold my extra lol. with the 2.6 and weight reduction i should easily go 11's same technique ive used. But id like to be told sir please remove your cobalt from the track shes too fast and you need a cage
Your running 80s and Meth?
If you don't already have one id look into getting a wot box
lol pm box is cleared. Ive said before a dyno is just a tool for comparsion and tuning. Trap numbers are what i like to see. but once i get on E85 i said im going to post all dyno sheets
ralli on my track runs i have first and second at 7200, and third at 7500. I may bump third a bit higher i duno i had some spark blowout before though so with that cleared up we shall see. I was thinking about holding her around 6800 when i launch
