Drag Racing Kindle Racing and Dalcorp Racing
ls turbo track results
Old Nov 12, 2010 | 11:20 PM
BlackCobalt707's Avatar
well after a very long and difficult time with this car i finally got decent results. bone stock i ran a 15.9 @ 88 wit a 2.2 60ft. modified, tonight i ran a 13.4 @ 111 wit a 2.4 60 ft. i got a couple other slips but they are crappy. the very last run i trapped 115 but ran a 14.7 (i couldnt get it in 2nd gear lol). this run was done on stock 195/60/r15 street tires (kumho or however its spelled)
Old Nov 12, 2010 | 11:22 PM
Perfect.disguise's Avatar
Congrats.
Your 1/4 ET looks pretty strong compared to the 1/8 et.
Old Nov 12, 2010 | 11:24 PM
dandaman15's Avatar
What kind of turbo set-up do you have? How much HP are you putting down?
Old Nov 12, 2010 | 11:31 PM
Originally Posted by Perfect.disguise
Congrats.
thanks. i think shes a 12.9 car if i can get a good launch down. turbo lag is a bitch, i dunno why its laggin so much but in the higher RPMs shes a ****** rocket
i have a custom turbo set up consisting of a 60-1 turbo, vulcan equal length manifold, 60# injectors, 2.5 hot side piping, 3" cold, 3" downpipe with high flow cat, ss/tc cat back, meth injected, forged rods and pistons, ferrea head, spec stage 2 clutch, and trifecta tuned
Old Nov 13, 2010 | 01:33 AM
InfraRedline's Avatar
Thats pretty impressive man. Good traps especially
Old Nov 13, 2010 | 01:59 AM
thanks
Old Nov 13, 2010 | 02:40 AM
_UnLiMiTeD_'s Avatar
A nicer set of tires will go a long way, the 60 foot is killing you. Nice trap speeds though
Old Nov 13, 2010 | 02:51 AM
Zdeuce4's Avatar
finally u hit the track.. sheesh.. man u need to get drags...u already knew this haha
Old Nov 13, 2010 | 02:55 AM
JacBlackSS/TC's Avatar
i couldn't believe you were boosted and they call my car a sleeper lol
but you did why better than me
Old Nov 13, 2010 | 09:01 AM
i got some 17s but one of the inside of the tire is gettin worn and i didnt wanna ride on it. i got some slicks i brought wit me tho but i was scared to push them cause i didnt wanna snap a axle cause i didnt feel like cashin out money for that lol. so when i did use them i had like 26 psi in em. next time ill do 18
i been hittin the track, just gettin shitty results until now lol. im thinkin about gettin drags for my 17s i got, so that way i dont gotta roll to the track with a jack, and 2 extra wheels and tires
that was my ultimate goal dude. i wanted it to look stock on the outside but kick some ass at the same time. i think ive accomplished my goal lol. your car has a hell of alot more potential then mine. you will be leavin me in the dust soon, especially if stock turbo tcs are runnin 11.9s on stock turbos
Old Nov 13, 2010 | 09:05 AM
freakta's Avatar
good job man, thats got some killer power
Old Nov 13, 2010 | 09:19 AM
thanks. ima dyno later. hopefully good results. i still got boost issues tho. boost builds as RPMs builds so its not leveling off
Old Nov 13, 2010 | 09:24 AM
Spanky's Monkey's Avatar
boost creep is what you got. nip that in the bud before it gets worse. how are you controlling boost?
Old Nov 13, 2010 | 09:26 AM
i dont think its boost creep cause i got my boost controller set all the way up, if i turn it lower it wont go no higher then 18. i got a AEM EBC. well i dunno man. if it is boost creep wouldnt it be goin higher then 18 if i got it set all the way up and i supposedly got a 13 psi spring in it?
Old Nov 13, 2010 | 09:43 AM
beast10007's Avatar
nice run!
I have the same size turbo forsale you should buy a back up y its cheap
Old Nov 13, 2010 | 09:55 AM
if i had the dough lol
Old Nov 13, 2010 | 04:59 PM
NotME's Avatar
******* badass times man, i remember seeing that thing last yr the last day of cecil. you going to hit up cecil next month? i plan to make the trip sometime in december
Old Nov 13, 2010 | 05:24 PM
thanks. i doubt ill be there in december, might go next saturday wit matt aka rallycobalt06
Old Nov 13, 2010 | 05:35 PM
bykryder83's Avatar
Nice!
Old Nov 13, 2010 | 06:12 PM
not satisfyin enough for me lol
Old Nov 13, 2010 | 06:31 PM
i'm a little confused are you saying with the aem ebc turned all the way down it wont boost past 18psi on your 13psi spring? but if you turn the ebc up, at the desired boost setting the boost will continue to build?
Old Nov 13, 2010 | 06:32 PM
oh eah ebc's ******* suck and fail a lot. not saying that is your issue but i'd suggest a good mbc.
Old Nov 13, 2010 | 07:34 PM
ralliartist's Avatar
17s are too big for drag racing to be honest. Drop down to a 15 and get a slick. You'll be much happier.
Old Nov 13, 2010 | 08:38 PM
yes sir. wit the EBC off it will make like 7-8 psi. with the duty cycle all the way to 90% 18 psi is all it made
i got 15" rota slips wit M&H slicks, im just too afreaid to snap somethin
Old Nov 13, 2010 | 08:39 PM
when i use a MBC the boost doesnt go as high for some reason. so its either a wastegate issue or bad couplers somewhere
