off to the track tomorrow
Last time I went to the track I ran a 13.8, with a 2.2 60ft<----iirc
mods were 2.7in pulley cai, vibrant header/dp, borla exhaust, ottp h.e., and dual pass
now I have single pass, and some pretty BFG drag radials 225/45/17 on stock ss/na rims
What do yall think I can get at the track tomorrow night?
oh and what tire pressure should I be running? I'm not quite sure....
Last edited by Dragonsfire12345; Apr 8, 2011 at 10:13 PM. Reason: Automerged Doublepost
ok well last night went pretty bad..... other than what I stated in my other thread in problems section. Well after the car regroups and I finish the run the IAT2 is freaking high right at around 158-168F
temp last night was in the 70s and humidity was in high 70s..... last time I went to the track it was in the 60s and the IAT2 was iirc 130-140. The only difference I did was the single pass and the way its routed.
It goes from IC pump>passenger side inlet of intake manifold> exits out driver side from all 3 exits(dual pass outlets) > stock he > secondary H.E. > back to IC pump
thats how I have the intake manifold enters from one side and exits through all 3 sides
I would expect extremely low 13 on your setup and dr if not high 12's.
Get that 60ft down a little and your good to go. As for tire presure my Pirelli i run at 22psi.
Best of luck keep us posted.
Did not see your where in texas, its gonna be hot most likely but at least a mid 13
