Quickest all motor 2.2?
#52
Alright back on topic
Lets get a list of what is needed for a high 14
Intake
2.4 intake manifold
Header
D/P
No bigger than 2.5 inch exhaust
tune
engine and tranny mounts
better tires
lower tire pressure
weight reduction (150lbs or more)
drag bags (maybe spring rubber, but I can't find what I saw once)
Good driver (2.3 or less 60'
Would that do it?
Intake
2.4 intake manifold
Header
D/P
tune
better tires
lower tire pressure
Would that do it?
i am almost there without half of that
#53
#55
Ive never mentioned anything about my 2.0 being anything high and mighty over the 2.2. gotta get the facts straight before the bullshit leaves the catapolt
And back onto the quickest all motor 2.2s before the next louse gets derailed again...
#56
Intake
2.4 intake manifold
Header
D/P
tune
better tires
lower tire pressure
Would that do it?
Intake
2.4 intake manifold
Header
D/P
tune
better tires
lower tire pressure
Would that do it?
I wish I was a good driver.
#57
What do you guys think a 2.2 with K&N intake, ported lsj header (stock exhaust), and 2.4 manifold would do with street tires?
I definitely don't want to walk away with 16's.
I'd be happy with 15's, anyone think I got a chance?
#60
Almost only counts in horseshoes and hand grenades. But yeah youre only about 300lbs away from 14's.
07: yeah the larger LE5 throttle body would most likely help, how much is debateable, since the manifold is the biggest restriction. What I am trying to find out is what is the difference between the 06-07 and 08 LE5 intakes, I dont have early style intakes to compare with, I really dont wanna buy two intakes even though I can just return the one I dont use.
I dont intend on hitting the track until I am sure I should hit 14's. Just collecting parts and throwing around ideas right now.
#61
#65
No one knows cause no one has tested it.
I promise they didn't change the mounting points for the 08 intake manifold.
It has to be the same or they would have had to redesign a lot. Which didn't happen.
THe MAP sensor might need to be honed out a little like on the 07 cars
#68
#69
i do up top but noithing significant. once i got the tune i am not sure if anything benefited from it, but i went to the track and ran my quickest time without it. put it on and nothing changed. the only time i feel it is when i downshift at seventy mph. not interested in going 90 mph all the time though i want the power downlow
#70
The 2.4L intake manifold works on the '08s and should give the exact same power increase(assuming youre not an '08 XFE)
The whole "08 thing that everyone talks about in regards to the 2.4 mani is actually a big misunderstanding and noone that Ive seen really knows wtf they are talking about they are just quoting CED. What do I mean?:
Well the 07-08 L61 both use the exact same intake manifold. They didnt redesign the L61 intake for '08 afaik. so why wouldnt it work/why would it offer different results??
WELL..........because the '08 LE5 manifold is different. The 06-07 LE5 manifold isnt the same as the 08 LE5 manifold. No ones tested the 08 LE5 manifold yet.
Ive got one of each coming this week(cant check 'em out till at least next week though since I ve got no money, so I wont be able to tear into the boxes without the parts mgr tearing into my ass.
#71
if i was rich i would do a before and after. Hell Maybe just maybe I'll try both of them at the track. The 2.4 TB for sure robs a little power down low, but up top it's lot a banshee.
Now if there is in fact an increase above 4k like I feel then on a drag strip it is worth it.
#72
