Drag Racing Kindle Racing and Dalcorp Racing
stock SS/SC, what gear at 1/4 mile?
Old May 20, 2006 | 05:20 PM
Bika's Avatar
Fail Less.
i have an ss/sc with just the airbox mod and a filter. still on 16" winter rims with shitty eagle rsa tires, i went to the track once and made 3 passes -
60' = 2.31
14.78 @ 96.7 mph
this run i wheel hopped horribly off the line, launching at 2000rpms and not feathering the throttle enough through the 60' i crossed the line in 3rd gear as i danced on the rev limiter.
60' = 2.43
14.82 @ 96 mph.
DESTRUCTIVELY wheel hopped through the 60' triggering my abs and e-brake lights to come on momentarily. launched the same as the first run but with 28psi in the tires instead of 32. not enough pressure apparently. i shifted into 4th at or right before the line.
60' = 2.28
15.8 @ 93 mph
best launch of the night and missed 2nd gear so after crashing violently into the rev limiter and putting it back in gear i barely managed to chase down my buddy with a base ls 5 speed. also shifting to 4th at the end of the run.
ok ok enough bs. my point is, in what gear do you people with stock SS/SC finish the 1/4 mile?
Old May 20, 2006 | 06:07 PM
yallabalt's Avatar
I have seen some where on this forum, 3rd gear. I do not race, do not know first hand. I have read else where 3rd gear.
Old May 20, 2006 | 06:11 PM
DanJHartman's Avatar
you should be close to hittin the rev limiter in the end of 3rd gear by the end of the quarter
Old May 21, 2006 | 11:58 AM
SilverSS/SC's Avatar
With the stock 6500 limiter 3rd gear at 100 or slower . All my passes I got @101 or more I had to shortshift 4th just before I crossed the finish line .
Old May 22, 2006 | 12:05 PM
Bika's Avatar
Fail Less.
thanks. i also think one of the factors throwing me off was the tires i have on those 16" rims are a bit smaller overall diameter than the stock pirellis, thus shortening my gear ratios just a hair. they were half worn 205/55/16 i took off a set of J-body rims before i sold them. before winter i will be investing in the proper size winter meats.
i have since put the stock 18"s on and i will try the 1/4 mile again soon.
Old May 22, 2006 | 12:08 PM
hatrickstu's Avatar
**** keep the 16's on and get some sticky drag radials, then you will be hauling ass off the line
Old May 22, 2006 | 12:22 PM
R33P3R007's Avatar
360 L337 User
I always hit the rev limmiter in third and f up my run, so I say the very begginning of 4th.
Old May 22, 2006 | 07:53 PM
JimzSS's Avatar
At the end the 1/4 mile you have 3 light beams...the first is the E.T., the second and third beams read how long it takes to go between them, hence getting the mph. i have always let 3rd gear run out and hit the limiter @ the e.t. light....experiment.. and,IMO, if you must, shift to 4th before the end.
Old May 22, 2006 | 08:01 PM
TexasPhil's Avatar
stock i was hittin the traps on the rev limiter in third.
Old May 23, 2006 | 01:40 PM
Bika's Avatar
Fail Less.
soon as i get a job that pays above minimum wages, im definitely gonna be getting a pair of stickies, among other things to help my traction. damn shitty job market
Old May 28, 2006 | 02:27 AM
redbaltsssc's Avatar
get the stage 2 you can go 110 mph in third gear
Old May 29, 2006 | 12:44 AM
maxpit's Avatar
I can agree with that.
Old Jul 6, 2006 | 08:28 PM
A_SS_THING_GT'S_WONT's Avatar
they say it best 100 mph or less 3rd i also short shift to 4th at the line.
Old Jul 6, 2006 | 08:31 PM
what is the stage 2 ur talking about maxpit
Old Jul 6, 2006 | 08:33 PM
hatrickstu's Avatar
if you dont know stage 2 search the forums for GMPP Stage 2
Old Jul 6, 2006 | 08:41 PM
patathSS's Avatar
i leave it in third, plus my drag tires are a little greater diameter than my stockers, so my speedo says about 102 but I am really at 105 or 106.
Old Jul 7, 2006 | 08:14 AM
Acidangel_5.0's Avatar
im winding out 3rd
Old Jul 7, 2006 | 08:22 AM
LittleStealthSS's Avatar
Well, I JUST ran last night, and had 5 passes.
Best time was a 14.9 @ 94.xx I had a 96 mph speed on another run, but it was @ 15 something
I was just about at the rev limiter in 3rd, and mine is 100% stock... no upgrades at all. Running my everyday Khumo ESCTAs on there as well. I had traction issues as you did, and couldn't do better than a 2.39 60' time. Lots of wheel spin. I do not have the G85, and I think that WOULD make a diff, could be wrong though.
I hit 4th once or twice.
Old Jul 8, 2006 | 01:52 AM
Blown 4-banger's Avatar
Last time I took my car to the track I was trapping 98.35 mph and was right at 6500 rpm and right (like a millisecond) before I let off the gas the rev-limiter just barly starts to bounce.
But there was another guy there with the stock rev-limiter and he was trapping 99.4 on the rev-limiter at the stripe.
TedSS
101
Apr 25, 2016 10:46 PM
camaromanss1992
Oct 1, 2015 10:51 PM
brett.higgins3
Sep 24, 2015 09:51 AM
Cptnslo
Sep 24, 2015 09:32 AM
Jacque8080
Sep 9, 2015 09:21 PM
