stock SS/SC, what gear at 1/4 mile?
i have an ss/sc with just the airbox mod and a filter. still on 16" winter rims with shitty eagle rsa tires, i went to the track once and made 3 passes -
60' = 2.31
14.78 @ 96.7 mph
this run i wheel hopped horribly off the line, launching at 2000rpms and not feathering the throttle enough through the 60' i crossed the line in 3rd gear as i danced on the rev limiter.
60' = 2.43
14.82 @ 96 mph.
DESTRUCTIVELY wheel hopped through the 60' triggering my abs and e-brake lights to come on momentarily. launched the same as the first run but with 28psi in the tires instead of 32. not enough pressure apparently. i shifted into 4th at or right before the line.
60' = 2.28
15.8 @ 93 mph
best launch of the night and missed 2nd gear
so after crashing violently into the rev limiter and putting it back in gear i barely managed to chase down my buddy with a base ls 5 speed. also shifting to 4th at the end of the run.
ok ok enough bs. my point is, in what gear do you people with stock SS/SC finish the 1/4 mile?
60' = 2.31
14.78 @ 96.7 mph
60' = 2.43
14.82 @ 96 mph.
60' = 2.28
15.8 @ 93 mph
thanks. i also think one of the factors throwing me off was the tires i have on those 16" rims are a bit smaller overall diameter than the stock pirellis, thus shortening my gear ratios just a hair. they were half worn 205/55/16 i took off a set of J-body rims before i sold them. before winter i will be investing in the proper size winter meats.
i have since put the stock 18"s on and i will try the 1/4 mile again soon.
At the end the 1/4 mile you have 3 light beams...the first is the E.T., the second and third beams read how long it takes to go between them, hence getting the mph. i have always let 3rd gear run out and hit the limiter @ the e.t. light....experiment.. and,IMO, if you must, shift to 4th before the end.
Well, I JUST ran last night, and had 5 passes.
Best time was a 14.9 @ 94.xx I had a 96 mph speed on another run, but it was @ 15 something
I was just about at the rev limiter in 3rd, and mine is 100% stock... no upgrades at all. Running my everyday Khumo ESCTAs on there as well. I had traction issues as you did, and couldn't do better than a 2.39 60' time. Lots of wheel spin. I do not have the G85, and I think that WOULD make a diff, could be wrong though.
I hit 4th once or twice.
Last time I took my car to the track I was trapping 98.35 mph and was right at 6500 rpm and right (like a millisecond) before I let off the gas the rev-limiter just barly starts to bounce.
But there was another guy there with the stock rev-limiter and he was trapping 99.4 on the rev-limiter at the stripe.
camaromanss1992
Oct 1, 2015 10:51 PM
Cptnslo
Sep 24, 2015 09:32 AM
