stock tc 13's?
stock tc 13's?
I want to run a 13.9 stock. First time ever to the track I went 14.6. This time I want to throw out a 13.9. Car feels like it pulls harder and is defiantly louder"all of this happened at 1700 miles after I left the track, never drove the catr that hard before that point" I want to know what things you did to pull of a under 14 sec pass with your ss/tc balt"stock".
Tire pressure?
Launch Control? " I launch at 2300" "never have used it"
Shift Point RPM?
When to leave on the tree?
NLS? "I do it threw all the gears"
What ever else you can come up with?
Thanks guys any input will help i feel this is very possible im super comfortable in the car know.
Tire pressure?
Shift Point RPM?
Launch around 2500, dont dump the clutch but slip it quickly. Shift 1st before 6K using NLS, then 2nd right at 62-6300 NLS again. Shouldn't need to hit 4th if you do it all right, you should hit the limiter RIGHT at the trap
I ran 13.9 @ 103 stock.
launch at 2200, feather clutch out, WOT at 4k in 1st, NLS @ 5800rpms 1-2 shift, 6k NLS the rest. I always popped into 4th gear on the 1/4 mile literally 50 feet before it ended (I would have bounced off of limiter if I didn't), see time below on stock tune.
Front 20psi
Rear 40 psi
Front 20psi
Rear 40 psi
Plenty of people are using NLS with tunes. I saw what Maven(IIRC) posted about the 3 tranny's but the common view Ive seen is those were flukes. Ive been using it 2-3 and 3-4 at the track without issue thus far.
I also would like to cut a 13 before the mods start-it's obviously doable but I have a tendency to launch too hard. I've played around with tire psi f/r-just wondering how much it really helps and how risky it is going too low up front(below 25 or so).
When it's all said and done driver mod and a good 60' should get it done. Also gained 2-3 mph by resetting ECU + K&N drop-in.
If you want to have a good e.t. you will want to NLS 1-2, and 3. Why is eveyone launching at such low rpm. It makes sense why so many people are running high 13's. You don't launch a car at 2500 rpm. We have been NLS are car all season, you shouldn't be hurting trannys on a 13sec car.
You must have better tracks then some of us. The one I goto almost has grooves in the start area and it grips right at the line then totally slick to the 60'. Hard to make a really good 60' time there.
