Drag Racing Kindle Racing and Dalcorp Racing
Turbo with 10.8:1 comp. pistons??
Old Jul 25, 2006 | 09:58 PM
Asphalt Assault's Avatar
The following is GM specs for the 2.2 performance team drag car.
Engine Type : Inline 4-cylinder
Displacement : 2.2 Liters, 3.500" bore, 3.505" stroke
Valves/cylinder : 4
Balance Shafts : Removed for high RPM operation
Block Material : Aluminum with steel cylinder liners
Head Material : Aluminum
Crankshaft : Billet Steel
Compression : 10.8:1
Camshafts : Custom ground, with roller valve finger followers
Induction : AirWerks by BorgWarner Turbocharger with air to water intercooler
Ignition : Capacity discharge by MSD
Fuel Delivery : Pectel T-10
Lubrication : Dry sump
Exhaust : 4 into 1, custom bent
Horsepower : 1250hp @ 9200rpm
Torque : 800 lb-ft @ 8000rpm
Transmission : X-Trac seqential
When ever I talk of replacing pistons people tell me to go lower compression to do a turbo one day. In the compact build book the suggest 8:1 or 9:1. and yet this build has 10.8:1 and GM did a build of an LSJ to be over 300HP with 10:1 pistons. Now obviously something in the recipe dictates the way to go. Help me out. I was planning on building up to the max with bolt ons as I dare to go. then pistons. then do the rest (head, cams, twin or turbo charged) anyone with thoughts about this.
Old Jul 25, 2006 | 10:04 PM
avro206's Avatar
well for one---they are using some seriously high octane race gas.
Wonder how much boost it runs?
Compression ratios and lbs of boost has both been steadily going up for years on production cars.
Old Jul 25, 2006 | 10:05 PM
Halfcent's Avatar
I'm old school
I am the man you need to talk to.
You are confusing a street machine with a race engine.
The car described above is a race machine that can never be legally operated on the street. The car uses Methanol, not gasoline, and only runs for about 10 seconds at a time. Therein lies your answer.
It's all about the gasoline. A street emmisions legal car can only use the highest octane pump gas that they sell at the local gas station. Sure, there are higher octanes, and sure, people use them on the street, but isn't legal to do so.
If you want a street machine, you have to design your engine around the street legal gas available to you, usually around 93 octane depending on where you live.
With that limiting factor, build you engine. A forced induction engine using 93 octane will be able to handle a larger amount of boost with a smaller compression ratio without pre-ignition or detonation. The idea being, get as much air and gas into the cylinder as you can and compress it as much as you can without the gas exploding. A nice, stable running engine that will be reliable and streetable.
Does that answer your question?
Old Jul 26, 2006 | 04:51 AM
CoBOT's Avatar
Very good post... just one thing. You can drive a methanol powered car legally on the street and most states will actually cut you a check for having such a clean running car. I know of a really fast (8s) and he drives it on the street. I might be thinking alcohol though... it's late I am going to bed if I am way off on this tomorrow I will fix it.
Old Jul 26, 2006 | 09:07 AM
I think I read that they run 42 to 45psi and have the capability to run just over 50psi. I feel I am being conservative about these numbers but I know I could be way off. It has been quite a while since I read that. I dont feel like pulling out the build book right now LOL.
Old Jul 26, 2006 | 09:19 AM
YES that does. Very good explanation.
I am mechanically enclined (for a back yard tech) and have managed auto repair shops plus one years apprentichship. I know quite a bit about cars and threories. Point being my opinion of your explanation is backed with some knowledge. I have racing experience too, but in motorcycles.
This is all new territory. I thank you for giving light to the situation.
GM and JBP are still recommending 10:1 and some people are doing 10.5:1. JBP knows what they are doing and I would follow their recommendations but I still want to understand.
Now with your explanation I am thinking to myself "whoa, I am definitely not going to the 10.5:1 and I really need to see how victory red SS's car turns out.
I thought of twin charged like this fella is doing but I am willing to get as much HP out of it with the factory blower. but the world is for ever changing and so will my mind LOL.
thanks.
Supercharged06SS
Dec 11, 2022 04:47 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
