Warren's 1/4mi Results
Ok imma scan a few in once I get around to it in the morn.
Car had the 18's on w/ KDW's, had roughly 100lbs of school supplies. another 100lbs+ for all my sub box and amp's. Skies were partly cloudy. Temp 46F.
And the best result was!!!!!
A 16.1.
R/T .154
60' 2.551
1/8m 10.488
MPH 69.29
1/4m 16.119
MPH 86.97
Something I desperately need is traction. This 16.1 was achieved on the edge of stock ls wheel hop. on a couple previous runs i took it just a tad too far into the powerband and hopped my a$$ through first gear. results from taking that bit too far pushed me into 16.3-4.
So my question is this.....should I go with the reversed mount's from OTT, or should I say screw it and get my 2.4 mani w/ retune. I figure either would break me into the 15 second barrier.
A 16.1.
R/T .154
60' 2.551
1/8m 10.488
MPH 69.29
1/4m 16.119
MPH 86.97
Sounds like you need some traction mods, but also a driver mod.
With those mods you should already be running mid 15's easily. That 2.5 60' is killing you. Get that down to a 2.2 and you'll be well into the 15's. If it makes you feel any better, I ran a 2.44 16.0 with all bolts on, but untuned. I'm an auto though, with you being a standard there's no reason why you shouldn't have a better 60'.
Good luck.
Good luck.
Were u running on the stock steelies?
On my fastest run, i held it at about 2800rpm and had the tires to that point where they are screaming but not quite losing all traction through about 4500rpm(know what i mean?) and chirped second.
considering it was my first time racing at the track in like 5 years I'm happy. i think i may just use some money i got coming in on the 2.4 mani/tune AND reversed mounts.
sorry to thread jack but im going to the track this summer for the first time what kind of times do u guys think i ll run considering those few mods i got?everyone keeps asking me what my times are so im just trying to get an estimate
I was running my 16" wheels in my pic gallery with bald ass tires.I lowered my pressure to 25psi then did a nice 2nd gear burnout to clean them off.The track i go to uses alot of VHT(traction aid sprayed on track)and if you dont burnout then you have lots of rocks stuck to your tires.
A 16.1.
R/T .154
60' 2.551
1/8m 10.488
MPH 69.29
1/4m 16.119
MPH 86.97
A 16.1.
R/T .154
60' 2.551
1/8m 10.488
MPH 69.29
1/4m 16.119
MPH 86.97
oh another thing youll wanna do is no lift shift(kepp the gas floored and just pop the clutch to shift)If youve never done this youll have to practice so you can get quick at it.Just from NLS i went from 16.18 down to 15.6. Then ported my stock exhaust manifold went catless and now im at 15.40 with stock exhaust manifold(ported)modified downpipe(catless)SS/SC resonator with full catback and a custom intake.NLS FTW
does this make sense or am i off by a lot?
Lots of things to do this summer.
New minimum mods for summer list:
Reversed Mounts
2.4 Mani/RE-tune
WOT-Box w/ NLS option only
perhaps with those 3 extra things in the cobalt, of course with extra practice at the track, will see consistent low-mid 15's?
Good luck.
Good luck.
The whole logic behind it makes sense. A typical shift for most is about .5 second(no NLS, but aspirated). I'm sure I'm faster on the shift than average but without being full throttle I'm still into that half second range). With an NLS shift not only are u still full throttle but your slammin the gears probably down to about the .2-.3 second range I'd imagine.
Ya thats how I went through my first trans lol.Toasted 2nd gear but Ive been beatin the hell out of the new trans and I cant break it haha.I powershift every gear.2nd gear makes the biggest diff when powershifting.I would try it once at the track.One time wont hurt it.Mine blew up cause i kept doing it all the time,run after run after run.But like I said the new trans is holding up quite well now
dammmn,
well hey NWAE in the next couple months I'll be coming up to Auburn area to see Vince about a new dyno tune for my car with the 2.4 mani installed. Perhaps I'll find some extra money for the lsj downpipe and a gmpp or custom exhaust. Depends how much money I'll come across. all i know is i at least wanna be hitting me low low 15's by end of summer. lol
ouch. You need driver mod I never got mine to a 1/4 track before i sold it but with just an injen CAI, vibrant header & dp, and gmpp cat back i ran consistant 10.1s and some 10.0X runs in the 1/8th. If i didn't use my driver mod it was up around 10.5, get your 60ft down and your time should be alot better
Get rid of the 18s for the track, the bigger the sidewall, the less chance of wheel hop.
The weight reduction would also help your times.
You should be able to pull a better 60ft then that, but dropping the rim size, and using a larger sidewall tire, and of course less tire pressure will really help you out.
Kevin
Kevin
dammmn,
if you need help installing we can do it at my house
and i have a couch to crash on if you need too
a 16.1 out of a toyota prius is remarkable. a 16.1 out of an L61 car is less than remarkable by a huge amount, especially with a 2.5 60'. get some 2.3xs or 2.2xs and be deep into the 15s.
Dont be going to the track with 100+ lbs worth of stereo equipment in the car, that's just plain stupidity.
same for the school stuff..... dump these two items and you have mid to high 15's end of story....
