9-3 and cobalt ss trans interchangeable?
Old Feb 16, 2015 | 12:30 AM
southal cobalt's Avatar
are the 99-2005 saab 9-3 f35's interchangeable with the ss transmission? down here i can pick up a used saab trans much cheaper than an ss's.
Old Feb 16, 2015 | 06:25 AM
It looks like the bell housing is kind of different look it up on Wikipedia
Old Feb 16, 2015 | 05:35 PM
i honestly cannot tell the difference between the m/t saab f35 and the gm f35. ive seen the autos look completely different. I would be surprised if they had the same linkages even. i just cant find a definite answer
Old Feb 16, 2015 | 05:57 PM
BoostedLemonPie's Avatar
maybe the splines on axle aren't same diameter?
Old Feb 16, 2015 | 06:17 PM
blueLNFftw's Avatar
They have to be the same bell housin since the b207 can go in the cobalt SS
Old Feb 16, 2015 | 06:37 PM
yellowsupercharged06's Avatar
John powell will have your answer.
Old Feb 16, 2015 | 07:00 PM
Powell Race Parts's Avatar
the bell housing bolts up but the shift mechanism is totally different both in the casting shaft entry and the actual external operation. It just wont work unless you are prepared to do a crap ton of fab work. Fifth gear is marginally taller also and no lsd. if that matters.
Old Feb 16, 2015 | 07:03 PM
blueLNFftw's Avatar
Is the clutch depth the same so you can use the LSJ fw, clutch and TOB?
If so, wouldn't the shift cables and shifter assembly be enough?
Old Feb 16, 2015 | 07:16 PM
I just said:
the shift mechanism is totally different both in the casting shaft entry and the actual external operation. I also said that if you want to convert your car to a SAAB trans it would take a lot of fabrication.
The GMPP is a SAAB clutch originally
Old Feb 16, 2015 | 07:38 PM
i figured he might lol
thanks a bunch!
Old Dec 12, 2020 | 06:24 PM
Bradley Shuler's Avatar
Definitive answer
so I’m just trying to double check, but will the 05 Saab 9-3 f35 clutch work in a 09 cobalt ss
TurboTechRacing
Oct 27, 2015 07:58 AM
Tupp
Sep 29, 2015 11:07 PM
brett.higgins3
Sep 24, 2015 09:51 AM
jcalvin1126
Sep 11, 2015 10:24 AM
Josh@ottp
Sep 5, 2015 07:46 PM
