All With Spec Clutches
Old Oct 9, 2006 | 02:30 PM
Floridas Finest SS's Avatar
Who all has a Spec clutch?
Whats the Positives and the Negatives?
Any Fitment Issues?
Any Slipping Issues?
Why go 2+ over 2?
How is the drivability of the stage 2+ or 2 especially if you have a lighter flywheel?
Sorry for all the ?s but i want to make sure i buy the best, and the exedy is a lil pricy for what u get.
Old Oct 9, 2006 | 02:32 PM
SSinPhilly's Avatar
Me I just got a Spec Stage 2. The Fit is great. I used a fidanza flywheel. It engages alot quicker, rarely ever does it slip.... Its not a big difference for daily driven.
Old Oct 9, 2006 | 02:38 PM
Thanks for the info, but rarely does it slip have you had it slip on you?
Old Oct 9, 2006 | 02:48 PM
SSinPhilly's Avatar
Yeah but I think slippage is in the computer for some reason I got it once after a few hard runs. Nothing major and it hasent happened again. I just installed the ingalls torque brace and it seems to firm the shifting up. I like the pair!
Old Oct 9, 2006 | 02:55 PM
Bad06SS's Avatar
I have the spec 3+, and it does fine. Clutch feel is the same as stock, and it's very strong. When we feel "slip" in these cars, I'm not so sure it's the clutch (if you have aftermarket). I've had a few issues at the track where the car won't go into 2cnd gear, only when it's hot. However, I think the issue is actually with the haydraulic lines not keeping up when the fluid is hot. I don't have any issues with the clutch itself. Get a 2+ or a 3+, not the in betweens, as the + series is a stronger clutch.
Old Oct 9, 2006 | 03:04 PM
WSFrazier's Avatar
I got the spec 3+ w/ spec flywheel. Right now, if I do a hard/fast 1-2 shift at WOT, it does nothing but grind. We are gonna try bleeding it for the 4th time and change the tranny fluid. I got 2500 miles on it so far, Im hoping with do time it just goes away, heard these things take a long time to break in.
Old Oct 9, 2006 | 03:06 PM
Bad06SS's Avatar
See, that's what everyone gets. I don't think it's the clutch itself. Our entire slave cylinder setup is stupid anyway. We need someone to come out with a better slave cylinder setup with better hydraulic lines, and then I think we'd be fine.
Old Oct 9, 2006 | 09:20 PM
Thanks for all your input guys but i'm at a loss with the clutch situation I might end up going on a gamble and getting the Exedy...
Old Oct 9, 2006 | 09:32 PM
06noscobaltss's Avatar
Intense Racing sells a slave cyliner. Yet I do not know what they did to it at all so I dunno if it will change the grind. Mine finally went away a month or so ago after like 10k miles on my stage 3 and flywheel! no slipping at all yet!
Old Oct 10, 2006 | 03:53 PM
PlaysWitCars's Avatar
Former Cobalt Owner
I dont have any slippage or grinding at all in mine
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
