another broken lnf tranny
Old Nov 1, 2012 | 10:43 PM
gmlifestyle's Avatar
Title says it all.....I have no 3rd gear....wondering where anyone can get em at a decent price.......shoot me a text 713 584 9426
Old Nov 1, 2012 | 10:47 PM
mexi_loco's Avatar
if you have a problem with 3rd gear, the whole tranny is not messed up. You'll just have to replace that gear. Most likely just the synchros though. It's a common problem. Just make sure to flush the tranny out really well.
Old Nov 5, 2012 | 09:44 AM
Ok ...thanks its already in the process of being built so....we will see how much tougher it shall be
Old Nov 5, 2012 | 09:55 AM
user 72239's Avatar
you broke it on stock turbo/bolt ons? did you NLS to 3rd?
Old Nov 5, 2012 | 10:58 AM
prevsrt4owner's Avatar
Sucks to hear, but likely a synchro.
Old Nov 5, 2012 | 04:30 PM
Stamina's Avatar
I've broken two with the stock turbo, one of them NLS'd less than five times. Never grinded any gears or missed any shifts/NLSs on the second one either. I think it's just how the power comes on, any wheel hop vs traction, and any drivetrain mods (like sticky clutch).
Old Nov 5, 2012 | 04:36 PM
thedubsack85's Avatar
WIth the way these transmissions are designed good luck finding a shop that can do a rebuild of just one gear/synchro. They are few and far between and charge alot for labor! the GM dealers dont even try most of the time cause it's a pain in the ass even with the specific tools required and if it's a warranty approved repair they just replace the entire transmission instead of the hassle of Rebuilding! Good luck! and post up if you do find a good shop that can fix it for cheap!
Old Nov 6, 2012 | 12:35 AM
Fastgti69's Avatar
Car-part.com
Old Nov 6, 2012 | 12:37 AM
cranemaster's Avatar
My 2nd gear syncros went, and they replaced the entire transmission because it was more cost effective than the labor
Old Nov 6, 2012 | 06:34 AM
While we're talking about transmissions, would it be better to get a used F35 with lower miles, or just buy from a vendor (modified/more stout)? I plan to keep the car stock, or maybe just a tune only. All I have is the MD, lol.
Old Nov 6, 2012 | 08:12 AM
user 72239's Avatar
if you only plan to keep it stock, then buying a used transmission would be your bet. if you plan on modding and making big power, a 4.05 or 4.45 would be your best bet
Old Nov 6, 2012 | 12:06 PM
Good deal! Thanks.
Old Dec 4, 2012 | 03:36 PM
Ok update my tranny is done .....got the whole thing cryo treated new 3rd gear new synchros,,, with 4.05 final drive....and over coarse did what zzp does to thiers ....torqued down harder then spec on the bearing preloads.....the only thing now is that my gears sound like their howling a bit....but runs really good....shifts are sharp and smooth... Mongolrat I can use some input!
Old Dec 4, 2012 | 03:59 PM
Powell Race Parts's Avatar
"cranking it down harder than spec on preloads" and now it howls? sadly is not a surprise.
we use shims.
600 dollars to rebuild an F35 plus parts. cheers. shipping is a pita.
Old Dec 4, 2012 | 04:11 PM
We used shims as well.....everything went back in like stock trans except evrthing was cryotreated including the shafts bearings crushsleeve etc..... So since their is more load on the bearings and gears. Is it normal?
Old Dec 4, 2012 | 04:17 PM
We have to make the spacers for the endfloat. I did Mongorats tranny and it was cryo'd , and we built it from a boxful of parts for Mongo, and he put it and he says its wonderful. Not sure what to say here.
Old Dec 4, 2012 | 04:44 PM
emiller's Avatar
Why did you over torque the bearings? The noise is them yelling f u for doing that.
Old Dec 4, 2012 | 09:25 PM
mexi_loco's Avatar
you said you got your tranny cryotreated? where in houston can you cryotreat your parts???
Old Dec 4, 2012 | 10:37 PM
Its not in houston...I sent it out of state
Old Dec 5, 2012 | 12:34 AM
Send it back....?
Old Dec 5, 2012 | 07:16 AM
I can say that piecing together a transmission from a box of parts like Mongorat's cryo'd one is not easy. We are fortunate we do so many, and have assembled trans here that we can pull apart to check things. That said, Mongorat had put everything stripped apart, carefully placed in plastic bags, all marked and everything perfect, but was still missing three small parts that would have made the assembly a disaster if we had missed that.
Good luck
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
OrangeCoba
Oct 1, 2015 10:00 PM
patooyee
Oct 1, 2015 01:07 PM
Iceberg
Sep 28, 2015 01:31 PM
