Anyone ever drilled their polyurethane trans. mounts?
Old Jun 17, 2008 | 07:27 PM
redblur's Avatar
I was thinking about my poly trans. mounts. The car vibrates....alot. Almost annoying when I sit with the a/c on, let alone at idle. I feel they're shaking my interior apart, but I love the no-wheel hop part of it. So here's my thinking....
My previous car was a 2003 Cav LS sport. I installed same style poly trans bushings, but these had 5 holes drilled in them around then center of the mount perfectly. Not bad vibes, stopped what little wheel hop I was having with 145 hp, and tightened up the shifter a bit. So if I take the current solid mounts I have, and drill 5 holes around the center perfectly, would that lessen the vibes while keeping it somewhat stiff?
Lemme know what you all think....Thanks!
Old Jun 17, 2008 | 07:30 PM
Red2.4SS's Avatar
i drilled my first set and it reduced the vibes somewhat but was still annoying.
i have a non drilled set now. long story.
but the vibes do calm down after about 1000 miles.
btw the vibes are less if you add the poly engine mount as well!
XM15's Avatar
How long have you had the mounts in for?
Old Jun 19, 2008 | 07:39 AM
TurboTechRacing's Avatar
#1 key thing is to have ALL the mounts, Turbo Tech Racing Upper and BOTH trans. By only having some mounts, you will have more vibrations, than if you had all of the mounts.
Old Jun 19, 2008 | 11:19 PM
Mr_Slobalt's Avatar
why doesn't anyone manufacture a poly/solid driver's side upper mount?
Old Jun 19, 2008 | 11:21 PM
hatrickstu's Avatar
i dont mind mine much at all...
Old Jun 19, 2008 | 11:25 PM
NinjaHampster's Avatar
i thought about the same thing but then the vibes died down alot. like it was previously stated just ride them out and everything will be fine but it does help out even more if you get ALL the mounts.
Old Jun 19, 2008 | 11:28 PM
nuttzzy's Avatar
i got a set im trying to get rid of cause i traded my car in
Old Jun 19, 2008 | 11:42 PM
Mr_Slobalt's Avatar
well, my rear transmission mount took a dump..the stock one...so I think I might just slip the aftermarket ones in since I have them all sitting in my trunk...first I have to find out what the hell is going on with my engine at work tomorrow, then on to the mounts maybe Saturday if I'm lucky....I hate putting things off
Old Jun 19, 2008 | 11:46 PM
Cobalt_SSTuner's Avatar
i like the vibes, makes me feel faster
I have lower motor mounts and trans mounts....
Last edited by Cobalt_SSTuner; Jun 19, 2008 at 11:46 PM. Reason: Automerged Doublepost
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
n20saturn
Sep 30, 2015 12:26 AM
Sep 27, 2015 08:53 PM
