ARP bolts for pressure plate?
Old Oct 21, 2012 | 10:14 PM
BumbleF__K's Avatar
does anyone know the part number for the bolts that bolts that hold the pressure plate on the flywheel? i know i can reuse them and blah blah blah, but the stock torx heads are junk IMO, and would rather replace them with arp.
If knowone knows the part number for ARP, I can use the thread pitch and height to order some then i will post up a part number. if i dont hear anything on here by tomorrow i will just measure myself and post a part # up
Old Oct 25, 2012 | 04:57 PM
BumbleF__K's Avatar
part number from ARP is 671-1017 for 12 points, they come in packs of 5 so two packs are required
Old Oct 25, 2012 | 05:04 PM
kxrida2000's Avatar
ya i stripped on of those shitty bolts one time. man was it fun getting that out...
Old Oct 26, 2012 | 01:30 AM
Frogstofall's Avatar
I think you we're talking about three different sets of bots. The bolts that hold the pressure plate down aren't Torx. The bolts that hold the flywheel to the crank aren't Torx either but ARP does make bolts for us for that application and they are 12 sided bolts.
The only Torx bolts in relation to the clutch that I know of are the ones that hold the slave cylinder to the Trans. You definitely wanna replace those if you can when you replace the slave. I just went to a Menards and got socket head cap screws.
Old Oct 26, 2012 | 09:20 AM
kxrida2000's Avatar
the pressure plate bolts are reverse torx bolts
Old Oct 26, 2012 | 03:25 PM
On what car? I've ripped out 3 trans and all the pressure plate bolts were standard hex head bolts.
Old Oct 26, 2012 | 03:34 PM
kxrida2000's Avatar
LSJ Pressure Plate Bolt 90470712
ive done 7 trannys in a 2.4, 2.2 and lsj haha. But we are both right they switched to hex for an lnf( good move)
http://www.crateenginedepot.com/LNF-...11013C701.aspx
Old Oct 26, 2012 | 04:52 PM
Ah okay, never done anything other than LNF.
Old Oct 26, 2012 | 05:02 PM
kxrida2000's Avatar
ya i guess chevy finally realized the **** idea and fixed it for the lnf
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
