Auto Leaking
Old Jan 5, 2012 | 11:43 PM
nhanson's Avatar
Auto Leaking
Saw a couple drips on the garage today. Found out my cooling lines are all wet and the subframe or engine cradle (whatever is directly below them) is all wet too.
These prone to leaking? Going to take to dealer..62k miles, tuned though.
Old Jan 6, 2012 | 12:37 AM
Sharkey's Avatar
the tune shouldnt matter, and if they say anything about it ask them how a non factory tune causes the cooler lines to leak.
havent seen many fittings leak, however where the hose is crimped to the steel line, ive fixed hundreds of those (not all cobalts or even gm, just common failure on everything).
Old Jan 6, 2012 | 01:55 PM
nhanson's Avatar
Looked closer and it looks like the lines are the problem. The whole case and pan of the trans is dry.
Old Jan 6, 2012 | 02:42 PM
bratboy90's Avatar
Time to get a Cruze and buy the ZZP EFR kit.
Just cut off the cooler lines and call it a day.
Old Jan 9, 2012 | 11:20 PM
nhanson's Avatar
Went in to get it fixed and they told me its not covered under 100k powertrain warranty. WTF
its 2 fittings and 6" of hose and you cant fix it?
Might email Chevy directly and see what they say. Guy at dealership even said Ford covers it but Chevy does not.
Old Jan 9, 2012 | 11:24 PM
Sharkey's Avatar
id try calling somebody higher up, those lines are required for the transmission to function correctly. if those lines leak out all the fluid the transmission will start to slip and eventually fail, then gm will have the transmission under warrenty
Old Jan 9, 2012 | 11:26 PM
nhanson's Avatar
Thats what my friend said. Let them rot and then take it in for a failed trans.
Cause technically if no "harsh" conditions are met then they say it never has to be changed.
Old Jan 10, 2012 | 12:25 AM
Sharkey's Avatar
honestly, i wouldnt wait till that happens. yes your car is under warrenty, however this could take a while and your warrenty may expire before the tranny fails from low fluid. end result is you could end up with a large bill caused by a simple problem.
Old Jan 10, 2012 | 12:37 AM
nhanson's Avatar
Yea I won't do that. I'll call or email then if no dice then ill fix myself
Old Jan 10, 2012 | 12:40 AM
ItalianJoe1's Avatar
Just drain a large portion of the fluid out and take it back with the trans slipping, let them put a new trans in it.
Old Jan 28, 2012 | 10:28 PM
bratboy90's Avatar
https://i.imgur.com/0t2kY.gif
Old Jan 29, 2012 | 11:37 AM
nhanson's Avatar
Got it fixed. Cooler lines were replaced.
Bullshit it wasnt covered though
bigdeertz
Nov 17, 2016 09:41 AM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
