Auto swap into a SS/TC?
then your not a serious drag racer.
auto > manual in drag racing
and to the OP. paul is performing this swap. i would wait until he is done so he can give you all the info
Last edited by BLAZIN07SS; Dec 28, 2009 at 11:07 AM. Reason: Automerged Doublepost
Gonna be expensive, and not necessarily worth the effort. If he really wanted to change it up he would go RWD auto with a stall kit. But we all know how easy it is to make a RWD Cobalt....
I am going to wait for Paul to finish but I was hoping I would get some other good opinions, ideas, incite, etc on the subject while I wait! Plus I think I read him say something about a 5 speed auto that he was swapping to. I am more than likely going to do the "easy' swap to the 4T45 from a HHR. So if he is doing a 5 speed auto then I am not sure how much it will help me unless the 5 speed proves to be a better option.
I agree with that. If 12's were my goal I would be finished with my car.
I'm not too worried what the stock trans will hold... I can always have it built to handle more power for now. Plus, I will more than likely go with the 4T65 in the future when fueling gets fully resolved with these cars.
Yes I know what a high stall torque converter is. Apparently you just make up your own words to describe things though, like "stall kit".
These are the only "stall kits'' google could find for me: http://www.tritonbarns.com/kit_stalls.php I have no idea how you would install one of these in a car.
Like I said before, please don't bother posting if you have nothing to helpful to add to the thread. I don't need people that have no idea what they are talking about telling me that my plans are dumb.
well, you're kinda asking for ideas and help, but not really telling us what you're trying to do. regardless of what you do, people will tell you that you're stupid, and doing it wrong, because people seem to not like to watch others succeed and do something different.
Anyway, I told you why its a bad idea. If you want a good drag car, get a RWD with an auto not FWD. People have tried changing the tranny on cobalts, and its a royal EXPENSIVE pain in the ass. You can get 11's on the stock FWD tranny ( zzp almost has 10's ).
If you really want to spend a small fortune, go for it. When you run into problem after problem, dont say I didnt tell ya so.
I know of one person on this forum that has started an auto swap into an SS/TC but he hasn't released any info. I was just wondering if anyone else out there has thought of or done one? Could it be as simple as getting a transmission, ECU, and harness from an HHR SS and swapping it into a Cobalt? Anyone have information about this? I really want to do an auto swap for drag racing. If it isn't feasible I more than likely wont be keeping this car.
3rd gear roll the car we're doing's trans exploded at 28 psi on a gt3076r.
Car is almost done, just waiting on some ss bends to finish re-working the adapter for the wastegate.
Can't really post up too much info, nor do I really want to on here.
Track times will be up though.
it's not fun, and going to be a pain in the ass with out the helping I had from a certain awesome member on this site. still a few issues needed to be iron'd out with the PCM, but it's almost there.
Looking into it more I think a 4t45 would basically be a direct swap from an HHR to a Cobalt. The 4T65 however, would need a little work to get in there. I do think it is possible however without too much headache. I think at this point I am going to go with the 4T45 however just to keep it simple.
Anyone know what transmission Paul is swapping into that Cobalt he is working on?
have to rewire most of the engine bay, change pedal assembly's add TCM, block off clutch line, move motor, custom mounts, custom programming, new shifter, shifter cables, rework most of the piping since the motor moves an inch forward and now straight up, rework down pipe, and if aftermarket turbo, move external wastegate, oil drain, custom axles, change wheel bearings, so far thats just about finished.
as what trans it is, not saying at this point.
Last edited by 06blackg85ss; Dec 28, 2009 at 12:37 PM. Reason: Automerged Doublepost
Paul, mind sending me a PM with some details? I would love to know more about what you have done and I think I am only the 2nd person even looking into to doing this. I know you don't want to say what transmission it is but, you are not doing a 4T45 swap, correct?
We call it a stall kit around here. Im not sure where youre from...
but anyway, that's why I"m running my rx next year. cobalt is back to a good ol daily drive, well if I ever decide to finish wiring it.
bad things about f35:
horrible first gearing, horrible drop from 1st to 2nd (garbage for towing in europe), weak trans case (thin cast aluminum), shitty gears (pressed powedered metal), shitty input shafts (CI)
bad things about auto swap
a bit of a pain in the ass to do, still about the same price as the 6 speed gearing (not including labor for install). need to upgrade clutches and torque converter for real power.
good things:
clutch upgrades are cheap, and trans rebuilds are pretty cheap on the auto's
torque converter can be strengthened and restalled for @$500
consistancy, will handle the power, never fall out of boost, consistant launches.,
not posting any more info on this until the car is done, and maybe I'll post it up on here, but I doubt it.
Last edited by 06blackg85ss; Dec 28, 2009 at 12:43 PM. Reason: Automerged Doublepost
not really, I don't see those 3.82 geared f35's holding up into the 10's and that's where we are going.
good things:
good things:
This is exactly what I wanted to do. There has to be some way for you to run the HHR computer. If you couldn't get that to work, IPT makes a trans controller that allows you to manually select the gear you want in at anytime. Its similar to what the mustangs use. There were a few for them.... I think Baumann, compushift and someone else made one. One of the kits turned the radio buttons on the steering wheel into shifting the gears. lol But IPT was the most reasonably priced, I'm not sure how well it would work... just a suggestion.
I went with the 2.4 auto and had it s/c 'd for now. But eventually I would like to convert a tc over.
I mean sure its not my money, but I would really hate to see someone spend all that cash and not be happy with the results or the long process to the end of the road. Look at victorys RWD build and the mess that has been.
Wow. Glad I have been posting on the other forum. Too much B$ in this forum.
And i love people who keep secrets. Thats why this community is so far advanced! Go look at any other forum, and there are tons of people helping people. IDK whats so hard about that.
Marcus, I will do some more research and post up on the other forum!
