Auto swap into a SS/TC?
Old Dec 30, 2009 | 06:29 AM
  #76
06blackg85ss's Avatar
Originally Posted by Maven
Okay, Ill just chime in with my thoughts on the subject for the OP.
Firstly the trans thats likely the best choice is the 4T45.
Its the only auto that will bolt to the ECO and to the Cobalt.
Any other trans (4T65,4T80, 6T45, 6T75) will either not bolt to the ECO (only the 6T45 does) or will not bolt into the Cobalt(none do) or worse wont fit without cutting the car
The 4T65 has alot higher capacity, but requires an adapter to fit the ECO, special torque converter(or adapter) and requires custom mounts and custom axles.
the 6speeds arent really even worth discussing, though if you search it has been before.
If you use a 4T45 plan on needing custom downpipe and charge piping, youll also need a different motor mount, youll need trans cooling, youll need shift cables, a shifter, a console trim plate, youll need axles, a flywheel
Youll either need to make the HHR electrical stuff work in the cobalt (not easy because of several reasons but chief among them is the difference in the vehicle harnesses) or youll need to run a standalone controller. One that can do the job all by itself isnt cheap or easy to setup properly, one that isnt expensive and is easy to use will make the car very unfun to drive everyday.
It would be much easier to pickup an NA auto car and build it. You should be able to find an auto car for under $5000 no problem
lol tell me about it, hopefully the thing is done before you come up for all the turbo goodness.
thank god for John, that is all
Old Dec 30, 2009 | 10:11 AM
  #77
Maven's Avatar
Yes mkriebs, you can use any 4t45 that was originally benind an ECO(HHRCobalt, etc) yes the axles from the HHR are needed. You need an auto flywheel from an auto LNF, thats the only flywheel that will bolt on.
Old Dec 30, 2009 | 02:55 PM
  #78
mkriebs's Avatar
Thank you sir!
Ok, talking with a few friends it seems there may be issues with some of the nannies in the car, that might be connected to the transmission. I was hoping I could get away without changing the electronics (wiring harness and TCU, mainly) by running a stand alone controller. I might be out of luck though.
I still need to do more research and give it a bit more thought on this though.
But, then again. I thought that HPT did not support the HHR Auto trans, and I was wrong! So, I think running the stock HHR wiring harness (or making a custom one) and TCU would be a nice option now, so we have stock like tunability, looks, and hopefully reliability, lol.
Not sure how it all would react to the modifications though, if we were to say... take out OD for extra clutches, etc...
Old Dec 30, 2009 | 02:57 PM
  #79
I posted up a thread with a link to my p.b. account.
has pictures of every job I've done including the auto swap
Old Dec 30, 2009 | 02:58 PM
  #80
mkriebs's Avatar
Where is said link, sir?
  #81
in my thread
Old Dec 30, 2009 | 02:59 PM
  #82
mkriebs's Avatar
Ah, thanks.
Old Dec 30, 2009 | 07:05 PM
  #83
marcusicp's Avatar
Thanks for all the replies! I have been away from the computer for a bit due to work but I will be back to continue researching on this soon.
Old Dec 30, 2009 | 08:16 PM
  #84
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/those-seeking-info-199931/
Old Jan 3, 2010 | 02:05 AM
  #85
mkriebs's Avatar
I think I am going to back out of this project. I think my time and money would be better vested in a straight cut gear set for the F35. It would not only benefit the majority of the consumers, it would be the cheapest, most affordable option.
I'll still keep an eye on this thread, and would love to help to the best of my limited abilities (when it comes to Auto trans).
Old Jan 3, 2010 | 02:25 AM
  #86
Maven's Avatar
Id love to here what you find when it comes to a spur gear set. I ant imagine youllfind its much cheaper than an auto swap Less involved, sure. But when the basically production level Quaife 6speed setup will run you over $4000 +install I am curious what a bespoke spur setup would cost, I cant imagine it would cost any less than the $4000 of the Quaife, and if youre looking for dog engagement Id raise the price up to like $7000+
Old Jan 3, 2010 | 02:28 AM
  #87
mkriebs's Avatar
No, no dog engagement. Just straight cut 1-4 gears, stock 5th gear, with synchro activation still. I think I could get it done for less than $2k, to be honest. I mean, look at the PPG sets for Honda's, they retail for $2600, and thats with markup. Since I would be getting it at cost, I would say quite a bit under that.
But, I have been wrong a few times before, so it could happen again. Its just something I am looking into.
Old Jan 3, 2010 | 02:44 AM
  #88
OriGinaL Condo's Avatar
I love that you guys are taking this car to another level. I wish you all the best of luck. I would love to see our cars start getting a little more diversity instead of everyone with 2.8 60#
Old Jan 3, 2010 | 02:47 AM
  #89
mkriebs's Avatar
Thanks! Lol. Its definitely gonna be an interesting endeavor. Should be fun though.
Old Jan 3, 2010 | 02:50 AM
  #90
Spins All Day's Avatar
You should have bought a 2.4 SS.
Old Jan 3, 2010 | 02:52 AM
  #91
Maven's Avatar
Yeah then look at the $4000 sets for Subies. LOL.
Old Jan 3, 2010 | 02:55 AM
  #92
mkriebs's Avatar
Touche! But, like I said, its something to look into.
Old Jan 3, 2010 | 06:30 AM
  #93
more like $7k lol.
Old Jan 3, 2010 | 10:59 AM
  #94
qwikredline's Avatar
yes I got that exact quote from PPG in Australia. And for Mkreibs, retaining synchros but going to straight cut gears is even more expensive. Wow...check out www. aintgonnahappen.com.... these are all answers to questions few people are asking and fewer still are prepared to pay for...
Old Jan 3, 2010 | 01:52 PM
  #95
Maven's Avatar
Originally Posted by 06blackg85ss
more like $7k lol.
Nah, you can get a 1-4 synchro/spur set for about $4000. It only when ou want the whole kit and kaboodle with steel forks and better shafts, or want dog engagement that the price goes that high, Dog engagement helical F23 with a proper diff would give me lots of lulz.
Old Jan 3, 2010 | 02:15 PM
  #96
slowswap's Avatar
**** it. All dog gears for whine all the time.
Old Jan 3, 2010 | 10:41 PM
  #97
ya there is a big thing for whine everywhere. Our Hollinger Z06 car 6 speed sequential straight cutgears, great box hugely robust, well everyone in the paddock comes over and wants to look at the supercharger. At the car wash here guys come up all summer long with whining hot rodded pick me up trucks - Gear drive timing gears is all.
slowswap wants whine with his dinnah....
Old Jan 4, 2010 | 12:30 AM
  #98
Maven's Avatar
Pete Jackson cam drive, unnecessary noise FTW.
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
ThoR294
Oct 4, 2015 08:44 PM
ThoR294
Sep 28, 2015 05:31 PM
