Auto Trans Interceptor
Old Nov 14, 2005 | 02:05 PM
redd214's Avatar
hey guys i got something for u auto guys. i havent seen this posted b4 so if its a repost sorry. anywayz jbody guys have been using these for years with great results. they increase the line pressure in the trannys and make them shift better. prolly wont feel it to much if ur stock but once u start bumping up the power itll help prevent slippage. its completley plug and play install takes like 5 minutes. they dont specifically have balts listed on there but the 4t45 is on there so im prett sure itll work for yall. happy modding
http://www.autotransinc.com/intercept.htm
Old Nov 14, 2005 | 02:07 PM
redd214's Avatar
also...
Auto LSD's
Yank Torque Convertors
Old Nov 14, 2005 | 04:19 PM
celicacobalt's Avatar
wow this would be great, i will wait till someone trys it out first though
Old Nov 14, 2005 | 04:20 PM
VaMP's Avatar
buy here:
http://www.carcustoms.net/product_in...roducts_id=296
Old Nov 14, 2005 | 04:25 PM
somebody try this quick
Old Nov 14, 2005 | 04:33 PM
olddude's Avatar
bumping the line pressure will indeed firm up your shifts, puts a lot of wear on hard parts though. I would find an actual shift kit that modifies the acumulator before using a resistor to fool the tranny into raising the pressure.
Old Nov 14, 2005 | 07:12 PM
redd214's Avatar
i know guys who have been using it for like 4 years on the same tranny, no problems. trust me it works.
Old Nov 14, 2005 | 07:14 PM
littless's Avatar
i have one, i will sell it for $50 bucks. it was used on my oldsmobile alero which was supercharged for 4 years and i never had problem or threw codes
Old Nov 15, 2005 | 10:14 AM
once i see this work im in
Old Nov 15, 2005 | 10:58 AM
RaineMan's Avatar
That does look pretty cool..... if I can work up $130 I'll think about it....
Old Nov 15, 2005 | 11:00 AM
littless's Avatar
i guess people don't read all the info listed on these topics. i have one that i am no longer using if some one wants it i will sell it for 50.00 plus the shipping.
just for the FYI these work great as i posted up three post i never had a problem and it is fully adjustable
Old Nov 15, 2005 | 03:21 PM
why selling it?
Old Nov 15, 2005 | 03:53 PM
VaMP's Avatar
probably because he has a Cobalt SS now.
Old Nov 15, 2005 | 04:01 PM
that would make sense
Old Nov 15, 2005 | 09:34 PM
littless's Avatar
this is true i no longer need it if you would like it let me know
Old Nov 16, 2005 | 10:06 AM
ill wait till i see some results then ill buy
Old Nov 18, 2005 | 11:14 PM
BlwnGP's Avatar
Stay away from "Auto Trans Interceptors" like the plague. They cause nothing but problems!
If the 4T45 is anything like the 4T65E, the "Auto Trans Interceptor" could cause severe problems with the transmission's ability to shift properly.
Coming from the Grand Prix community, they have been out for about 6 years for us and are virtually worhtless. People have tried them, and then got rid of them just as quickly as they bought them. They just don't work.
If you want to improve shifts, you have to do it mechanically by either: a shift kit, bigger transmission pump, better solenoids, improved valve bodies, or more clutch material/wave plates.
You can also accomplish this by a reprogrammed PCM that adjusts the values in the computer.
These "Auto Trans Interceptors" are about as effective as the "Tornado Air Intake". Completely smoke and mirrors!
Please stay away from them at all cost
Old Nov 18, 2005 | 11:20 PM
VaMP's Avatar
the 4t45 is nothing like the 4t65
Old Nov 18, 2005 | 11:46 PM
BlwnGP's Avatar
How so?
They are both 4-speed automatics, right?
They both have valve bodies, clutch packs, wave plates, accumulators, pumps and solenoids, right?
The both are derrivatives of the Hydramatic series from GM (4T_5 family), right?
IIRC, the race Cobalts use the 4T65E-HD as the transmission (heavily modified internally, of course), so we know that they bolt up to the Ecotec motors, right?
In fact, the GM Torsen differential (not the Quaife) used in the race cobalts is a direct swap into the Grand Prix's 4T65E-HD transmission as long as you use the 3.29 ratio version.
These transmissions, although not identical, are at least "kissing cousins".
The point wasn't if these transmissions are similar or not, it was that I was trying to save someone from making a big mistake by purchasing an "Auto Trans Interceptor" based on many years of past experience with similar situations. There are better solutions out there....it may take some time, however.
Has someone tried to contact TransGo about developing a shift kit for these cars (they have a very good reputation among the GP community)? That should be the first start if you want to improve shifts. Bet one could be put together for under $100.
Old Nov 18, 2005 | 11:56 PM
VaMP's Avatar
They are both 4 speed transmissions from GM but that doesn't make them remotely the same.
The 4t65e bolted to the Ecotec 2.2l with an adaptor plate. The 45e is a smaller transmission and designed for more economy based driving. It's clutch packs, wave plates, accumulators, pumps and solenoids are built to a 'lower' standard then the 65e because of the horsepower output the transmisison was designed for.
Also the PCM on the 65e is very picky, about everything, so I wouldn't be suprised if the GTP community did have problems the interceptor.
However, many people have used these on various transmissoins and have seen postive results and websites that sell them don't carry BS products like electric superchargers.
Old Nov 19, 2005 | 12:20 AM
BlwnGP's Avatar
You bring up some valid points about the differences. However, I believe (I may be wrong here), that if you want to improve shifts it is better and more durable to do it mechanically first. I would recommend a shift kit before any electronic gizmo anyday.
I have over 60,000 mles on my shift kit in my GP. I am putting out approx 320 horse with about 400 ft-lbs torque (calculated at the crank), and I still can bark second at will, lite them up on a 30mph roll downshift (2-1) and it shifts hard as hell. I am not light on this car (as no one should be with a supercharged car ), and it has held together so far. The 4t65E's are known to grenade with about that much power. Sometimes with much less power too. GM rates their max torque at about 280 ft-lbs. That is what the motor puts out when it leaves the factory No factor of safety what-so-ever.
I am a firm believer that my shift kit, along with a trans cooler, are the only things holding it together.
We will find out shortly next spring how much more it will take when I add some more power.
Old Nov 19, 2005 | 12:26 AM
BlwnGP's Avatar
Regarding the 65e's PCM:
They are not picky at all. All parameters can be changed/accessed. All you need is something like a DHP Powertuner or an HP Tuners software suite, a laptop, and some know-how. True, the PCM does have some torque management parameters that you need to know what you are doing when changing, but not any more than any other car with an automatic transmission. You can change shift points, account for gears, change line pressure, adjust the rev limiter, etc... very easily.
The transmission, itself, is the picky part of the equation.
I see you have heard about electric superchargers too. Quite funny actually...much like the Tornado.
Old Nov 19, 2005 | 12:35 AM
VaMP's Avatar
I cannot believe that your 65e has lasted thus far, lol.
Yes any mechanical change out of the transmissions internals would severely improve its overall performance. But, what we are faced with here is a bunch of shop fees (unless you know how to do it) and expensive parts as apposed to a $150 plug'n'play computer for the transmission. The type of person that would be interested in this in the first place would be one that couldn't really afford to pay $2000 to have their transmission made rock solid.
Old Nov 19, 2005 | 08:57 AM
yeah if this is gonna cause any problems its not worth it ill just save my money and build the transmission thats like a good $3k right?
Old Nov 19, 2005 | 10:13 AM
littless's Avatar
Again i had this on my alero as well as many other people on the alero boards. the 4t45e is rated to handle 300ft lbs unless that has changed my alero was put 325 to the ground with 300 hp. i too was very hard on my car and i never had any problems with the tranny while i had this installed. i did however put and addtional tranny cooler on as well, which is always highly recommended when doing hard driving like this.
Trans go does not offer a kit either"no intrest in this tranny" i tried that route as well when i had the alero. the olny kit that is out the is B&M they have a kit for i think it was 49.95 or something like that. people also had real good luck with it.
it all just boils down too how much do you want to spend, how much do you want to work at the install, and how much power are you going to add.
bigdeertz
Nov 17, 2016 09:41 AM
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
