Axel Insatll Question
Old May 11, 2008 | 04:16 PM
HidKidSS's Avatar
ok i have a question for you guys...i just blew my cv boot an had 2 get a new replacement driver side axel now my question is how much of a pain is it 2 do it yourself?
i really hate taking it 2 a shop couse ive done everything on my car myself an kinda would like to keep it that way untill i get 2 my clutch an flywheel that which i still might do myself
now has anyone every changed there axels or upgraded to the stage to an installd them themself? if so how bad was the removel an install can you post any helpful tips hints anything that you think will help
i should be getting the new 1 in durning the week an didnt wanna post it while im in the middle of an install
Thanks in advance
Old May 11, 2008 | 04:37 PM
2K5SS/SC?'s Avatar
It's not too bad. Take the wheel off, remove the two lower shock bolts, disconnect the sway bar links, remove the axle nut, and take the spindle out of the lower A-arm. This will allow you enough play to move the suspension parts around, pull the hub towards you and slide the half shaft out of the hub. Then you just have to pop it free from the tranny with a big screwdriver or small pry bar.
Old May 11, 2008 | 04:42 PM
HidKidSS's Avatar
ight thanks...hopefully i ran into no problems doing this ::cross fingers::
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
