B&M Shifter Problems
Old Jan 9, 2007 | 06:14 PM
CobaltSS313's Avatar
Is anyone having problems shifting with their B&M shifter, like it not wanting to go into gea, etc???
Old Jan 9, 2007 | 07:06 PM
SSdan's Avatar
Try adjusting your shifter cables. Mine doesnt give me any problems at all.
Old Jan 9, 2007 | 08:00 PM
adjusting them how??
Old Jan 9, 2007 | 08:02 PM
BallsoutBalt's Avatar
It has to do with the two white clips that connect the rods. Try to play with those to dial it in.
Old Jan 9, 2007 | 08:04 PM
06rallyss's Avatar
i notice it but only when its cold out and i havn't drivin it in a few hours but after shifting a couple of times it goes away
Old Jan 16, 2007 | 11:30 PM
SStud's Avatar
I'm having problems going in and outa gears also but i've determined mine was because of the Clutchmasters FX400.
Old Jan 16, 2007 | 11:32 PM
rickyw's Avatar
i have that problem with the factory shifter
Old Jan 16, 2007 | 11:41 PM
2K5SS/SC?'s Avatar
The whole Clutmasters fiasco took it's toll on my linkage. Slowly but surely it got messed up, and I can barely get into any gear now. New linkage set is on order though since the clutch issues have been fixed. $127 for the set.
If your shifter is in adjustment, and your linkage is fine you need to check the roll pin where the linkage connects to the transmission. On that piece, the roll pin has been known to break easily causing shifting to become a nightmare and non-existant. It's under the fuse box if you didn't already know, and it will be a bitch to replace due to limited work space.
Old Jan 16, 2007 | 11:53 PM
WSFrazier's Avatar
Operator error or CM FX400. How's the Meth kit coming?
Old Jan 16, 2007 | 11:56 PM
SStud's Avatar
No doubt, CM FX400. I have to go all the way to the floor and then some to get it to go in and outa gear. Plus the dang thing rolls with the pedal on the floor while i'm in gear.
Old Jan 17, 2007 | 12:16 AM
2K5SS/SC?'s Avatar
SStud, as you probably already know that is the same issue I had with the second pressure plate. The third version fixed that issue for me. I cetainly would buy a Bully clutch or Exedy one over the CM one for sure though. It sucks how we have to pay out the ass for someone elses R&D mistakes!
Old Jan 17, 2007 | 12:52 AM
SStud's Avatar
I agree totally. I even made sure this one had the CANA marking on it before installation. And the dang thing still didn't work. I called CM and they told me it was the dealers fault and that it was probably damaged durring installation. I'm looking at the bully lineup now for a new clutch but TAG is holding some info from us right now that they are supposed to release this week.
Old Jan 17, 2007 | 12:58 AM
2K5SS/SC?'s Avatar
Well, I hope their clutches work out better for everyone.
Old Jan 17, 2007 | 01:07 AM
SStud's Avatar
You and me both.
Old Jan 17, 2007 | 07:17 AM
djt81185's Avatar
Which gears? If its 2,4,R ur shifter cables are snapped. I had 2 sets go in 6k miles with teh B&M...0 in 27k miles with the stocker
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
