B&M Shiftplus Questions
Old Apr 22, 2008 | 10:01 PM
chevyLSchik's Avatar
yea it has a stock setting....
Old Apr 22, 2008 | 11:16 PM
originaladrian's Avatar
Originally Posted by -Jayson-
i know its not safe and yes it will void your warranty. That other guy spewing crap out of his mouth doesnt know what he is talking about.
The way this product works is it causes your trans fluid pump to work at either 50% or 100%. Now yes the pump was designed to work at those rates, but when you turn this on, its constantly at those rates. It can very easily burn out your trans pump and just destroy your trans. The way your trans normally works is right before its supposed to shift it ups the line pressure with the pump to allow the shifts to be normal, then quickly goes back down. With this kit its constantly running at 50% or 100%.
Like said before by someone, after using this for a while stock doesnt feel right anymore. I had one on my last car a 2001 Cavalier Z24 Supercharged. After about a year of use, if i turned it off the trans would slip so bad i would have to let off the gas in order for it to shift.
And again, THIS DOESNT MAKE YOUR CAR FASTER!!!!!!!
QFT.. almost (does make ur car faster, i would bet money tht an auto is faster down the strip after this, might not add HP at least ur tranny wont be slowing you down)
Originally Posted by INDColtsFan18
But can't i just leave it in the off postion unless im racing?
you wont want to... trust me =)
Last edited by originaladrian; Apr 22, 2008 at 11:16 PM. Reason: Automerged Doublepost
Old Apr 22, 2008 | 11:27 PM
~Coby~Kid~'s Avatar
does anyone want to sell their B&M shiftplus? i want one real bad!!!
Old Apr 22, 2008 | 11:33 PM
TTR has them, there cheap
i might be selling mine, depends on how the tune goes....
Old Apr 22, 2008 | 11:57 PM
mrsilent13's Avatar
like i said try ebay i got mine for $11 bucks and that included shipping.....
Old Apr 23, 2008 | 12:09 AM
averagewhiteboy's Avatar
****. For 11 bucks I may still give it a whirl. lol.
Old Apr 23, 2008 | 08:43 AM
-Jayson-'s Avatar
no it doesnt make your car faster, i tested mine at the track. I ran a 14.7@92MPH with it on setting II and i ran a 14.7@92MPH when it wasnt on at all. This was done when i just put it on so my trans was in good shape. And like i said my car was a better test car than most of yours because i had an additional 50HP running through the trans.
Old Apr 23, 2008 | 08:59 AM
maybe its cuase i cant even drive on the stok setting anymore, but i kno if i were to take my car to the track tmrw, i would def run a lower time with it on. my tranny really does lag and takes a good 2 seconds to shift without the shift+.
Old Apr 23, 2008 | 09:57 AM
-Jayson-'s Avatar
are you seriously trying to say the shiftplus makes your car faster because it damanged the trans so bad you cant drive it hard without it being on, therefore making it a worth while buy?
Another note on the testiment that this will ruin your trans. I eventually removed mine permanately because it was causing drivability issues. After a few hard runs and hard shifts, the transmission would start acting really funny. I would be cruising at a normal speed and the trans would just start to randomly up and down shift on its own, with no throttle change of my own. It would just bounce up and down between 2nd and 3rd gear. If i turned the shiftplus off, the trans would act normally as it could as this point. Or if i let the trans cool down it would act normally again.
Old Apr 23, 2008 | 10:38 AM
  #36
mrsilent13's Avatar
well if ur tranny is getting hot...why dont you get a tranny oil cooler...ive had one installed since before the b&m shift+. the stock tranny cooler sucks ass
Old Apr 23, 2008 | 10:43 AM
  #37
no it makes my car faster by reducing the time it takes to switch gears? how is this not making ur car faster? ya, i most likely screwed my tranny up a bit. no kidding, but i do ride my car very hard on stg 2 day nd night.
Old Apr 23, 2008 | 10:46 AM
  #38
blackjack hotrods's Avatar
I don't really need anything right now. Maybe down the road a bit if/when I go turbo, but by then clear image will probably have tuning to include the auto trans. I'll wait for them.
Old Apr 23, 2008 | 11:14 AM
  #39
-Jayson-'s Avatar
alright you guys are idiots, you want to screw up your cars so you can feel cool and chirp your tires like you have a manual be my guest...
guarantee i have done more research, have more knowledge, and more personal experience with this than any of you.
Old Apr 23, 2008 | 01:02 PM
  #40
mrsilent13's Avatar
watevers we do wat we want
Old Apr 23, 2008 | 01:24 PM
  #41
I'm not going to argue with you that, at 23, you have more experience than everyone here. But isn't the purpose of the Shiftplus to lower shift times in order to reduce internal clutch slippage and prolong the life of the transaxle? I mean I'm no 23 year old. I'm just a 34 year old ASE certified master technician with over 10 years of experience working on GM vehicles. I may not know what I'm talking about. Granted, there are kids on here who just want to chirp their tires and try to be cool, but not everyone who has posted on here is an idiot. Of course, if someone installs something like this they should be prepared that it might have adverse effects on other components like axles, ball joints, motor mounts, control arm bushings and even strut mounts and bearings. There are down sides to the product but, as far as the transmission internals are concerned, I'm sure it accomplishes it's intended results when used properly and resposibly.
Old Apr 23, 2008 | 01:53 PM
  #42
mrsilent13's Avatar
big props to you my friend
Old Apr 23, 2008 | 02:11 PM
  #43
quoted for extreme amounts of truthyness!!!
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
