B&M Short Throw problem?!?!
Old Jan 13, 2008 | 07:20 PM
quicksilver41's Avatar
This is not my first Short Throw install and this is my first Issue with one. I can not get it to go into reverse. As anyone had this problem and if so can I get someone to help me out on this one.
Thanks!
Old Jan 13, 2008 | 07:23 PM
saunders1986's Avatar
i think u need to adjust ur cables, did u mark them before u removed them?
Old Jan 13, 2008 | 07:24 PM
Super_SS's Avatar
wit the bm knob on there,when u go into reverse u have to go up and over into reverse..thats if u did everything else correct
Old Jan 13, 2008 | 07:28 PM
kenhebe's Avatar
X2. You need to adjust the cables. Marking them prior to removal (like the instructions say) is the best way to do it. If you did not mark them, then you jsut have to play with the cables till you get it right. The tech at my shop that installed mine marked the cables prior to removal so adjusting it was a breeze.
The other issue we faced is that when we tightened the ball all the way down, it would not go into reverse because the reverse lock out hit the ball. We loosened the ball just a little bit and that gave it enough clearance.
Old Jan 13, 2008 | 07:31 PM
They were marked before hand like the instructions said and still not working. I have been messing with it for about a hour now with no luck!
Old Jan 13, 2008 | 07:32 PM
ml2242's Avatar
There is a small silver insert that locks reverse in the LS, that i discovered when installing my short throw, the SS/SC may have it too its really hard to find if you don't fix it by tomorrow ill go out and take a picture and you can see if you have it / its the problem.
Old Jan 13, 2008 | 07:33 PM
kenhebe's Avatar
Take the ball off and see if it works. If it does, then you need to loosen up the ball. If it doesn't then it is not adjusted properly.
Old Jan 13, 2008 | 07:36 PM
Which ball are you talking about?
Old Jan 13, 2008 | 07:37 PM
kenhebe's Avatar
The shifter ball
Old Jan 13, 2008 | 07:40 PM
Ok, it goes half way into reverse, but will not go all the way down?
Old Jan 13, 2008 | 07:42 PM
kenhebe's Avatar
Then the cables are not properly adjusted.
Old Jan 13, 2008 | 07:44 PM
I guess more adjusting then, I was just wondering if anyone else has had this problm.
Old Jan 13, 2008 | 08:47 PM
Super_SS's Avatar
nop,i have the bm and installed it myself,and no problems at all till this day
Old Jan 13, 2008 | 10:59 PM
I gave up after about a hour, I will mess with it after I finish somethings on the Cavalier tomorrow.
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
