B&M Short Throw problem?!?!
This is not my first Short Throw install and this is my first Issue with one. I can not get it to go into reverse. As anyone had this problem and if so can I get someone to help me out on this one.
Thanks!
Thanks!
The other issue we faced is that when we tightened the ball all the way down, it would not go into reverse because the reverse lock out hit the ball. We loosened the ball just a little bit and that gave it enough clearance.
There is a small silver insert that locks reverse in the LS, that i discovered when installing my short throw, the SS/SC may have it too its really hard to find if you don't fix it by tomorrow ill go out and take a picture and you can see if you have it / its the problem.
Take the ball off and see if it works. If it does, then you need to loosen up the ball. If it doesn't then it is not adjusted properly.
