Brake Fluid for Clutch Sys.
Old Oct 12, 2007 | 10:07 PM
05_Blue_B10WN_SS's Avatar
I searched an could not find a specific answer. I purchased an Exedy Hyper Single clutch, pulled my trans, had a quaife LSD installed, and am getting ready to put the trans back into the car. I have trans fluid, but i need brake fluid to bleed the clutch line. What type of brake fluid does this car take?
Old Oct 12, 2007 | 10:17 PM
Cobalt_Supercharged's Avatar
Owner's Manual says "Delco Supreme 11 Brake fluid or equivalent DOT-3 brake fluid."
Old Oct 13, 2007 | 02:25 PM
R&C_rallySS's Avatar
Just finished up my install. The clutch/flywheel is awesome and yes you use DOT 3 Hydrolic brake fluid. You should only lose a small ammount of fluid. Good luck!
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
