View Poll Results: Would you buy a ShepTrans Built Cobalt Tranny?
Yes, I would DEFINITELY buy one!
65
39.88%
Maybe, depends on the price.
73
44.79%
That sounds cool, but I'd probably never buy one.
22
13.50%
No, we don't need one... our trannies are bulletproof in stock form.
1.84%
Voters: 163. You may not vote on this poll
Built Shep Trans Interest Thread
Old Aug 26, 2008 | 01:53 PM
  #76
Area47's Avatar
Rent me! per hour
Originally Posted by Edubs
Yeah, the problem w/ that theory for me, was it starting with an Exedy...
...now it's Exedy, S2 axles, upgraded knuckles, custom spherical rod ends in the rear mounts on the A-Arms arms, TRANS, etc, etc...
hell im back to square one again on the valve train. so go figure.
it's one of those "while im in there" things that got me in trouble with this car. if it breaks make it stronger.
Old Aug 26, 2008 | 02:05 PM
  #77
Edubs's Avatar
You sir, have a PM...
Old Aug 26, 2008 | 07:39 PM
  #78
Josh@ottp's Avatar
We are looking into stronger gears but they will be costly. Right now we can rebuild f35's and have them cryoed while they're apart. We are also looking into mikronite...
Old Aug 26, 2008 | 07:50 PM
  #79
burntorange's Avatar
Talking
There is different gearing to take into account as well. The TC's have longer gears... which should put a little bit less strain on the trans.
And Time-to-Torque is faster on the S/C version. If all you ever saw was a stock boost gauge in an SS/SC... then you don't know the true meaning of instant boost.
Yes, the SS/TC spools fast... but in the battle of Time-To-Torque, the S/C will always win.
Either way, the TC is hitting MORE torque. I was just trying not to pass the curse on to you guys.
If you want it... it all yours!
Why the hell would you want 4.45 gears? That would effectively make 1st gear useless/pointless.
I have never been able to get anything near the slightest bit of traction in first, ever since I started modding the car, and I don't go to the strip much anymore because everytime I go I always break something So all of my stuff is from 40+ and fourth gear is killing me lol Also, I have a lighter crank and flywheel which the longer 4.05's lug my car down horrifically....now, once I hit like about 4K the car takes off like a rocket, but other than that daily driving, with the A/C on, isn't the greatest thing.
Old Aug 26, 2008 | 07:59 PM
  #80
06blackg85ss's Avatar
Originally Posted by steddy2112
A firewall, half a block, and three giraffes
lol.... damn giraffes.
Old Aug 26, 2008 | 10:48 PM
  #81
spike's Avatar
new final drives would rock......something like a 3.82-ish
Old Aug 26, 2008 | 11:39 PM
  #82
yellowshowbalt's Avatar
whats this mikronite??? i havent herd of this....
Old Aug 27, 2008 | 05:52 AM
  #83
USMCFieldMP's Avatar
Rattlesnake Race Shop
You guys can operate on the F35?
I have two that I need combined to make 1.
The Second Gear Synchro blocker ring in Trans #1 is bad... and Trans #2's diff exploded... so I figure Trans #2 can donate its 2nd gear Synchro to Trans #1.
Could you guys make that happen? If so, PM me with an Estimate please.
Old Aug 27, 2008 | 05:53 AM
  #84
steddy2112's Avatar
Buy one from GM.
That's the final drive for the SS/TC
Old Aug 27, 2008 | 06:01 AM
  #85
Buy one from GM.
...its a little bit more complicated than just buying a new one, iirc. I read in the F35 service manual that it is the width of the output shaft that determines that final drive... but that doesn't seem right.
Either way... it'll be a hell of a lot of work.
Old Aug 27, 2008 | 06:05 AM
  #86
steddy2112's Avatar
Sounds like the F35 is the trans from hell...
Old Aug 27, 2008 | 06:09 AM
  #87
Yes... it is. Especially when just about no one has the proper tools to take one apart.
Which is why I had to buy a third transmission instead of getting the parts from #1 & #2 combined to make a good transmission then.
Old Aug 27, 2008 | 06:10 AM
  #88
steddy2112's Avatar
Sweet ******* god
Old Aug 27, 2008 | 06:19 AM
  #89
Yeah. I hope you've got the LSD... because the open diff's suck. And don't shift from 3rd to 2nd too hard. Pics are in post #1.
Old Aug 27, 2008 | 06:22 AM
  #90
steddy2112's Avatar
I do have LSD
All my problems are 1-2
Doesn't grind.
It just locks me the **** out.
For no reason, other than I am trying to no lift.
Old Aug 27, 2008 | 06:28 AM
  #91
Yeah... 1 to 2... you can't really no-lift shift. There is no fast shifting allowed from 1 to 2.
I get that a lot too. Seems to happen the most when I get a phenomenal launch at the track.
Old Aug 27, 2008 | 06:32 AM
  #92
steddy2112's Avatar
Advertise a car that can NLS
Then put a tranny that won't let you do it.
Old Aug 27, 2008 | 08:49 AM
  #93
rrutter81's Avatar
hopefully not as retardedly high as the quaife 6 speed.(just the gears)
Old Aug 27, 2008 | 08:57 AM
  #94
victory_red_SS's Avatar
LSX RWD S/C conversion
Yes... it is. Especially when just about no one has the proper tools to take one apart.Which is why I had to buy a third transmission instead of getting the parts from #1 & #2 combined to make a good transmission then.
It really has nothing to do with the "right tools" and everything to do with "competency"
I had a shop install the Quaife in my DD and they had never seen the inside of these tranny's before. When it came to the "special tool" they were to cheap to buy it so they made their own version of it. The transmission worked flawlessly.
Old Aug 27, 2008 | 10:36 AM
  #95
Josh@ottp's Avatar
Ya I have about half of the special tools, there is no way in hell I was gunna spend the 5k on all of them when they are just not needed.
Also the reason you need an output shaft to change the final drive is because the driving gear for the final drive is part of the shaft.
Mikronite is a surface finishing that improves wear and friction.
Old Aug 27, 2008 | 03:37 PM
  #96
BoostedYards86's Avatar
fast98 keep us updated on any news with your trannys
Old Aug 28, 2008 | 07:24 PM
  #97
Josh@ottp's Avatar
Will do guys.
Old Aug 29, 2008 | 08:27 AM
  #98
I do have LSD
Doesn't grind.
don't know if you are having the same problem as I was having but when I was at the track it kept doing the same to me because I was barely pulling up on the reverse lock out mechanism....I just get really excited to shift and stuff hahahahaha maybe this can help you? but that is what is about lol
when you say Quaife do you mean six speed?
Last edited by burntorange; Aug 29, 2008 at 08:27 AM. Reason: Automerged Doublepost
Old Aug 29, 2008 | 11:42 AM
  #99
Originally Posted by burntorange
.....when you say Quaife do you mean six speed?
Ooops, sorry I just meant the quaife lsd.
I had thought about the quaife 6 speed but I am not supposed to be modding my daily driver.
Old Aug 30, 2008 | 04:34 AM
  #100
hahahahahaahaha neither am I!!!!! ......which is also my ONLY car....and I am currently stuck at home...
anything new on this?
Last edited by burntorange; Aug 30, 2008 at 04:34 AM. Reason: Automerged Doublepost
