Can a 2.2 automatic bolt up to a 2.0 engine?
Old Feb 7, 2007 | 11:11 PM
NJHK's Avatar
Originally Posted by Halfcent
The j-body cars used 4t40's. The deltas use 4t45e's. The whitfield car uses a 4t60. The bellhousings on the LSJ and L61 are indentical. The trans would bolt up just fine. You would not be able to use it however. The 4t45e is an electronically controlled trans. The PCM in the CobaltSS is able to control a trans, but isn't programmed to do so. The trans equipped cobalts use separate engine controls and trans controls.
What he said lol
Old Feb 8, 2007 | 02:46 PM
skydragon26's Avatar
Will thetre be a way to control it through hp tuners or some sort of tuning software? im not up and up on tranny tuning so to speak
Old Feb 8, 2007 | 03:21 PM
06blackg85ss's Avatar
anyone know which model 4t60 they used, and how much of a bitch it was to bolt up.. I"m going to be in serious need of one quite soon.
Old Feb 8, 2007 | 04:05 PM
BlwnGP's Avatar
The GM Ecotec drag build book says that they use a 4T65-EHD out of a W-Body and convert it to a 3-speed in the 1300hp drag car.
The PCM has coding in there for all three transmissions (the 2 manuals and the automatic), GM does it that way for whatever reason. Funny thing is the Grand Prix PCM has coding to run a Getrag 5-speed in it too. You just need HP Tuners to open and activate the table in there for the automatic.
I think it would make an interesting swap, since that means that us 'matic SS owners (of the 2.4L variety) could swap in an LSJ powerplant too!
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Tupp
Sep 30, 2015 08:18 PM
