Can you run Solid Engine mounts and rotated trans mount?
Just as the title said, i hear from a few people that you can run both, and others say you can't. Using what i learned in my engineering classes, logically i feel like they both shouldnt work together. If the solid engine mount keeps the drivetrain in the same position and the rotated mount changes the orientation by 17 degrees, i feel like they shouldnt work together. The thing is I read that alot of people run both. I ordered the ottp rotated trans mount and plan on buying the ttr solid engine mount if they are compatible together. Any Input would be greatly appreciated
From what I know you can, the thing with the solid upper mount, they metal is just a different metal and is stronger then stock. The polyurethane that is in mount is still flexible enough to allow for motor movement and for the pitch of the engine to change. With the different polyurethane, they are rigid, yet flexible. The bushing will last a lot longer then stock and is just more packed together then the stock rubber bushing.
I ran the OTTP rotated trans mounts when they were made by John Powell. John recommended running the stock engine mount with them. He can explain why better than I can. But basically the engine has to be able to flex at some point. If there is no room for movement, you are going to start breaking things...........
Also Shawn the rotation is not even close to 17 degrees (That is almost half of a 45 degrees). It is MAYBE 1.7 degrees, if that. The rotated tranny mounts move at a MAX of ~.5" in any one direction.
I have zzp's rotated mounts and turbo techs upper engine mount. I get a lot of vibration at lower Rpms. So what I'm reading here is that the stock upper engine mount is best with rotated mounts.
Yeah I know its an old thread, but can anyone explain why a solid mount and rotated mounts would break things?
I have ottp stage 2 moints and a zzp solid engine mount. I wana make sure that I dont break anything.
Think of how the rotated mounts move the engine up and forward. The stock mount allows for a bit of flex which works perfect for rotated mounts. With a solid mount, it is designed to keep the motor in the stock location very firmly and not flex like the stock one would.
Good thing I found this thread... I don't have any mounts but wanted some. So all I need is the stage 2 rotated trans mounts to stop wheel hop?
2009 SS/TC zzp catted dp, k&n sri, muffler delete, zzp tuned pcm, zzp fmic
Good 20k on it and no Issues. Just adjust it right.
He's talking about the ingalls...
I wouldnt run the ingalls with a rotated mount, and if you read up a few posts you will understand why. BlackSSs2 didnt have any issues, but due to the fact the ingalls is designed to limit movement of the stock upper engine mount it isnt ideal.
I removed my ingalls when I installed my powell rotated mount, and it was a nice upgrade indeed.
By itself it's fine for a lightly modifed car.
But once you install the rotated mount it is not needed.
other than the vibes but its worth it.
