Can you run Solid Engine mounts and rotated trans mount?
You can save some money and just purchase a S1 rotated mount and run a SS/TC rear mount. You will get just about the same wheel hop reduction with a little less vibes.
Good tires and suspension will help with wheel hop as well.
Yes. The stock upper engine mount is more than adequate. You can save some money and just purchase a S1 rotated mount and run a SS/TC rear mount. You will get just about the same wheel hop reduction with a little less vibes. Good tires and suspension will help with wheel hop as well.
2009 SS/TC zzp catted dp, k&n sri, muffler delete, zzp tuned pcm, zzp fmic
The SS/TC rear trans mount is $86 new from CED. I paid $50 new back in the day.
You can get a used one as well.
If you have an SS/TC, you are already set. Buy a S1 mount and call it a day.
I mentioned to get the rear SS/TC trans mount because it will cause less vibrations and is just as good at reducing wheel hop.
That too. Although the stock mounts suck even for daily driving because of all the slop.
I have powells front mount and a spacer under the ss Tc rear mount and it's awesome. The very few times I have gotten hop I just let off the gas. Big deal lol
Also, people need to start understanding the stock upper engine mount it more than adequate for a performance setup. A solid upper mount is only going to cause excess vibrations.
As blackssstg2 mentions.... do not run a solid upper engine mount with a rotated trans mount.
Thats what I run. Also, people need to start understanding the stock upper engine mount it more than adequate for a performance setup. A solid upper mount is only going to cause excess vibrations. As blackssstg2 mentions.... do not run a solid upper engine mount with a rotated trans mount.
I've looked at these a few times a just wondered how they are:
ZZPerformance - ZZP Control Arms for Cobalt/Redline #ZZ-CA-CBT-BLACK
I can't tell really looking at the reviews.
Someone bought these to cure high speed braking.... when im sure they just needed new rotors or tie-rods.
M62 ecotec sunfire I had poly(stiffer than stock) engine mount, trans mount, and ctrl arm bushing installed for the last 200k of its life.
The shifting was a lot better and it felt more beast, but the vibrations were a bit too much for a pleasant DD. I could bear it back in my early 20's but not anymore in my late 20's. Don't even think about turning on AC it makes it 2 times as worse. And holding a doobie while holding the steering wheel it could shake the cheery right off onto your pants/floor.
TurboTechRacing
Oct 27, 2015 07:58 AM
