can't shift into 2nd...
Old Aug 30, 2012 | 02:18 PM
Tjolley's Avatar
i have about 60k on my ss sc.
I have a Zzp s4 clutch and fidenza flywheel
30k on the clutch
I can't seem to get the car into 2nd gear during a pull.
I pull on the shifter and its like there is nothing there.
I already checked the roll pin its good.
any one have problems with the shift cables stretching
Old Aug 30, 2012 | 02:20 PM
TommyP's Avatar
AWD > FWD
"Can't **** into second"
Let me fix that thread title for you
Old Aug 30, 2012 | 02:21 PM
Tjolley's Avatar
Oh dang...my bad
Can't shift into 2nd
Old Aug 30, 2012 | 04:34 PM
bluebalt07's Avatar
I've been having issues with 2nd also except mine is when downshifting. Kinda curious to see what the replies are on stretched cables
Old Aug 30, 2012 | 05:31 PM
Tjolley's Avatar
Its eather that or a clutch problem. I was told to change the master cylinder and rod. I think that could be my problem. Im just wondering cuz i went to the track the other day and had to baby it into 2nd..
Fastest was 14.02@100.5 missing 2nd
Old Aug 30, 2012 | 08:23 PM
bluebalt07's Avatar
If it was a problem with the clutch or master cylinder, wouldn't it show at other times too? Like engagement height, pedal feel, etc.?
Old Aug 30, 2012 | 08:30 PM
donkeyballs's Avatar
You might need to adjust the shifter throw. If its grinding into 2nd it could be the syncro.
Old Aug 30, 2012 | 09:47 PM
bluebalt07's Avatar
Was that directed towards me or tjolley? Lol and mine doesn't grind, it just feels like something is blocking me out of 2nd gear
Old Aug 30, 2012 | 11:12 PM
Tjolley's Avatar
Its like something is stretched. Cuz i checked the role pin it was fine. So its got to be a stretched shift cable or a really bad syncro...i don't think its a syncro cuz wen u pull hard to shift its like nothing is there
Old Aug 30, 2012 | 11:30 PM
you can adjust it so it goes in easier.. does 5th gear go in smooth?
Old Aug 30, 2012 | 11:49 PM
Tjolley's Avatar
Yes...i tried adjusting it
Old Sep 1, 2012 | 08:08 AM
Tjolley's Avatar
Ok i think i narrowed it down to the linkage or the shifter itself..cuz if u sit with the car off and move the shifter from first to second feels the same..i don't think a syncro will cause the shifter to have to move farther to get in to gear...hmm TWM time i think
Old Sep 2, 2012 | 11:19 PM
DarkChild's Avatar
I have a TWM and that WON'T fix your problem. My car is doing the EXACT same thing yours is doing. I have never had a car do that to me. All my other gears engage perfectly fine. And no, it doesn't grind. Under normal conditions it goes smooth.
Old Sep 4, 2012 | 01:14 PM
Tjolley's Avatar
I have the fuse box out right now.
Im gona have to make a tool to get the pin out. It seems to be stuck in there. I also can't hit it hard enough cuz of clearance issues..
Old Sep 5, 2012 | 11:35 PM
Tjolley's Avatar
Ok well finally got that ******* role Pin out...the pin looked ok...nothing seemed to change...i still have slop going into 2nd gear..
Old Sep 13, 2012 | 12:07 AM
DarkChild's Avatar
We need to find out if it is that adjustable rod that ZZP sells. My transmission is in perfect working order. I should not have this problem either.
RaginChopsuey
Oct 27, 2015 01:27 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
The Rookie24
Sep 20, 2015 04:33 PM
roadrunner132
Sep 19, 2015 04:35 PM
