Car is jerking while cruising or accelerating
So I have had this problem lately with my cobalt jerking while accelerating onto the highway or if I have it in cruise control and I have to travel uphill and it needs to accelerate. I was wondering if anyone else has had this issue and/or if it is something i should get checked out.
My cobalt is a 07 auto lt.
Thanks in advance.
Thanks in advance.
like 4 years ago i had a 2.2, automatic.
i'm not saying this is def. the case, but it's normal to feel a little kick when getting on or off the throttle quickly. if you ease on or off the throttle, you won't feel it. but push the gas halfway down from a coast, and it will be there.
when it jerks, is it with fairly constant throttle position (for merging) or cruise? or is it more when there is a change in the throttle position?
i've noticed my ss doesn't always run smoothly in cruise - i think its attributable more to slop in the driveline/motor mounts, etc and the switch from coastdown to applied throttle which comes with cruise. you might be seeing the same thing, but i'd imagine that the torque converter would minimize to a degree.
next time its in cruise, listen to the engine around the jerk. an engine under load will sound different than a coasting engine. if its under load, that might be part of it.
or, to be more of a smartass, get your car a girl, so it doesn't have to jerk whenever you decide to put it on autopilot.
Last edited by flobeelicious; Mar 15, 2009 at 08:30 PM. Reason: Automerged Doublepost
To determine if the hesitation is engine knock. If the engine is knocking on regular fuel and not when running premo then the plugs way be fouled or have build up on them causing the knock. If the knock is gone due to a gas that is harder to ignite(higher octane) then that can be ruled out. Not to mention if its shell V power the gas has more solvents/cleaners in too... And if I'm wrong and my idea is complete BS whats trying gonna due??
And last time i used injector cleaner I remember it needed a higher octane gas.. i think..
breds2k
19
Sep 21, 2015 10:24 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
