Car will not engage any gears
hey guys for some reason i can't update/change/ or post on https://www.cobaltss.net/forums/driv...-wrong-307335/
which is my original post.
i just replaced the clutch, flywheel, TOB/Slave Cylinder, elbow w/ bleeder valve, TOB line, and clip. Its all back together, but none of my gears are engaging, it does feel like its going into gear its just not catching. i lifted the front wheels off the ground and tried it that way, the front wheels move but not faster that 10mph and i can stop it with my hands. It also goes into gear when the car is on without pushing the clutch.
Anyone ever had this problem?
What could be wrong?
Needs more Bleeding? Clutch pedal feels normal like before to me.
maybe possible oil on the clutch face?
or since i broke my cable clamp and i removed, but i tried adjusting them and nothing.
What does the neutral position look like on top of the transmission where the cables connect?
Thank you.
Thank you.
Why would you start taking apart piece inside the car when they all worked fine before you started this job? Quit taking more things apart and focus on what you already did because something you did already is wrong.
What does the shift feel like?
Did you put the cables back on the right shifter arms?
i took the inside cables off because i broke the clip and got a new one to replace it.
gears go in like normal without pushing in the clutch.
and i can check the cables to see if that helps.
