Car wont move in any gear
As stated my car wont move in any gear. I put it in to 1st gear and try and take off and the car acts like it is in neutral. I tried it all five gears and reverse and still nothing. There are no visible leaks under the car and i really dont know what the heck is going on. Any help is greately appreciated.
no suspension work the car is bone stock...... it feels like it goes into gear like normal but it just wont move when i release the clutch and accelerate???
The car would knock BAD during normal operations while turning and it this just surprised the hell out of me I was not even expecting it!
Last edited by yellowchevyracer; 12-25-2009 at 01:14 AM. Reason: Automerged Doublepost
Its the round thing that comes out of the transmition, goes to some ruber boot, then another round shaft, that goes to another boot next to your wheel.
so i pulled the hell out of both axles and looks like thats what it is for know.... the driver side one was sounds like it is releasing air when you tug on it and the passanger side one seems okay... the broke one had some gunk seeping from it was is it ? Thank for all the help!
Well i had my wife step on the accelerator and the broken axle spins but wheel will not turn. The other axle just stays in place. Could it just be a axle that i need to replace?
Last edited by yellowchevyracer; 12-25-2009 at 02:03 AM. Reason: Automerged Doublepost
Haz l33t wheelz.
i think mine is a little bigger problem its snapped in half. How long does it take to replace an axle and would i have to replace both or just the damaged one?
Install is reverse of removal.
Good luck.
P.S. How do you snap an axle clean in half, and just randomly one day the car doesn't move?
Go down to your local parts store and get one. They are about $60... I did this when I broke one of mine.. I bought mine from an Orielly's
Left and right are the same part # as well..
http://www.oreillyauto.com/site/c/se...alt&vi=1433737
yep, just the axle. jack up the car, pull off the wheel. Undo the bolt in the bottom of the knuckle that pinches the ball joint, remove the knuckle from the control arm. Remove the abs sensor connector. Remove two strut to knuckle bolts. Remove axle, it may require an axle puller from Autozone (you can rent)
Good luck.
Good luck.
Last edited by yellowchevyracer; 12-26-2009 at 06:35 PM. Reason: Automerged Doublepost
An Axel is not something i would trust getting at a Junk yard.
With a locking diffrential the vehical SHOULD be able to move (one wheel drive) with a snapped axel. It will torque stear like a ************ though.
Good luck.
Good luck.
breds2k
19
09-21-2015 10:24 AM
