Clutch bleeding problems
Old Oct 2, 2016 | 10:35 PM
Sarahtim315's Avatar
I have blood the clutch at least 25 times I have clear fluid no air bubbles coming out of the slave cylinder bleed screw clutch is still engaging a right off the floor. Please help me I am a newbie to these cars 07 cobalt SS supercharged brand-new clutch disc plate throw out bearing in slave cylinder.
any help will be greatly appreciated thank you
Old Oct 2, 2016 | 11:49 PM
ItalianJoe1's Avatar
Factory clutch?
Did you try a vacuum bleeder? I have had great success bleeding it with vacuum as the factory procedure calls for, and seen a lot of people have issues when trying to bleed conventionally, although there are many who say it can be done without issues.
I made a simple stopper for the brake fluid cap opening and stick a little hand vacuum pump into it, pull down 20in/hg and leave for 5 min or so, then release and pump the pedal slowly 10 times, then re-apply vacuum. I do this 3-4 times while i'm buttoning up the top of the engine bay at the end. Once I get a nice firm pedal, I am done bleeding and never have to touch the bleeder screw or have a second person.
Old Oct 3, 2016 | 12:27 AM
exninja's Avatar
Second using the vacuum bleeder. The bleed screw is before the slave so you can easily trap air in the slave. Vacuum should do better at pulling it out.
Old Oct 3, 2016 | 12:49 AM
Sharkey's Avatar
another method ive had work well on various hard to bleed clutch systems is to very slowly push the pedal down, hold it for 5 seconds then release it quick. the theory behind it is while slowly pushing the clutch down the air bubbles sort of stay put in the line, and while holsing they will move back to the part thats trapping them, and releasing it quick will "pull" them back towards the master cylinder, and they eventually will get worked out.
Old Oct 4, 2016 | 03:38 PM
dlhiser's Avatar
I am having trouble bleeding mine as well.Could the bleeder screw be in a worse place????
I will try the above method.Worth a try.Thanks
Old Oct 5, 2016 | 12:42 PM
T-Man's Avatar
Did you replace the master clutch cylinder? If you put in a brand new clutch, it makes sense to replace the MCC right along with the slave cylinder.
When I purchased #3, the clutch pedal released right off of the floor and it was mushy garbage. I replaced the master clutch cylinder and it's good as new. No amount of bleeding is going to save an internally worn MCC.
Old Oct 5, 2016 | 03:29 PM
dlhiser's Avatar
I am buying a vacuum bleeder today.Hope it works for me.
Old Aug 7, 2020 | 08:30 PM
Dustin k's Avatar
Originally Posted by ItalianJoe1
Factory clutch?
how did you make a stopper please show me what you used
Old Aug 7, 2020 | 09:04 PM
Go to Amazon and look at rubber stoppers, they should list the dimensions and fine one that fits. Then take a drill bit to make a hole the bleeder can pull vacuum on
Old Aug 10, 2020 | 02:27 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Or go to a junk yard and buy a second brake reservoir cap and modify it to hold pressure.
Or just spend the extra coin on a ready made one:
Amazon Amazon
And as an FYI, I've never pressure or vacuum bled the brakes or clutch on this car, and I've had great success with having good pedal feel. It becomes a two person job though, but it's simple.
Old Sep 11, 2020 | 09:15 PM
Old Sep 11, 2020 | 09:20 PM
noorj
Jan 3, 2013 05:28 PM
motoxkfx
Dec 23, 2011 03:29 AM
turbaltss
Aug 15, 2010 01:14 PM
tlake84
Nov 24, 2009 12:46 AM
BlackSS/SC
Aug 6, 2009 05:08 AM
