clutch decision......
Old Oct 26, 2009 | 12:03 PM
bulletpound's Avatar
alright iv looked over many treads over clutchs btw exedy hyper and centerforce DFX and i still cannot come to the conclusion of which one to go with. some say the centerforce is really good then some say otherwise and its $300 less than exedy and comes with a aluminum flywheel.
hyper single- 6 puck, steel flywheel
centerforce DFX- 6 puck, aluminum flywheel
im not looking to get a separate flywheel so thats out of the question.
my mods are
2.8
60lbs
ottp h/e
ottp dual pass
ottp intake
opt. b
vibrant header/dp/cat-back
custom tune
future mods at most will be:
2.7
meth
i would like people that have both clutches to chim in and help which one should i go with....
Old Oct 26, 2009 | 12:06 PM
BLAZIN07SS's Avatar
I'm too JDM for you
exedy hypersingle. make sure you order the LNF 08+ Throw out bearing/Slave cylinder, new flywheel bolts and clutch pipe to ensure a good install
Old Oct 26, 2009 | 12:10 PM
http://www.crateenginedepot.com/stor...7-P1893C0.aspx
that bearing?
and what clutch pipe ( alignment tool?)...?
Old Oct 26, 2009 | 12:14 PM
BLAZIN07SS's Avatar
I'm too JDM for you
http://www.crateenginedepot.com/stor...P2478C229.aspx
http://www.crateenginedepot.com/stor...P2252C229.aspx
http://www.crateenginedepot.com/stor...P2253C229.aspx
no these
Old Oct 26, 2009 | 12:21 PM
SCcobaltSS's Avatar
What is the main difference between the two? What are the holding limits on both? 1k on a clutch is crazy IMO.
Old Oct 26, 2009 | 12:23 PM
the lnf clutch bearing fits the lsj? and its odd that if its better its also cheaper
also i no to order the bearing and bolts but why the pipe??
apparently the DFX torq rating is aorund 400-450
and exedy is about the same??
Last edited by bulletpound; Oct 26, 2009 at 12:23 PM. Reason: Automerged Doublepost
Old Oct 26, 2009 | 12:33 PM
BLAZIN07SS's Avatar
I'm too JDM for you
the LNF bearing doesnt have that crappy rubber boot the LSJ one has. The clutch pipes are known for leaking so its a good time to replace it.
i have to re-do my set-up now because the LSJ bearing is leaking
Last edited by BLAZIN07SS; Oct 26, 2009 at 12:33 PM. Reason: Automerged Doublepost
Old Oct 26, 2009 | 12:37 PM
thanks for the heads up!
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
