Clutch experts needed
Old Nov 27, 2015 | 12:19 AM
firehawk618's Avatar
Hello, here's my dilemma.
I finally got a trans that works properly in my car and now I need to figure out a solution to my clutch.
Before I replaced the trans I had many different issues with the trans but one of them was a HIGH RPM impossible to shift issue. When at high rpm's it just flat out wouldn't go into the next gear. The clutch fully disengaged when normal driving and when stopped. I suspect now that it was something wrong inside the trans causing this issue but wasn't sure at the time of R&R the old for new trans.
So when I too my old trans out I discovered the car had an aluminum flywheel + Clutchmasters FX300 setup in it.
I had a new LUK setup on standby because I was pressed for time to get this trans swapped and didn't have enough lead time to pick up a GMPP setup.
So I pulled the FX300 and put in the LUK setup. Needless to say it doesn't hold full torque. It slips a bit toward the top of 2nd and will slip in 3rd once boost ramps up. I turned my torque down via tune and now it's holding because of that.
I am going to pull the trans one more time to swap out the clutch.
I have ordered an OEM steel flywheel. The aluminum one is too jumpy rpm wise when taking off for my taste.
My question is, do you think I would be ok with the LUK clutch disc + Clutchmasters PP + Oem steel flywheel?
I really don't like the near on / off style of the kevlar discs and want to avoid that if possible.
From what I have heard the main component in a clutches torque holding ability is the pressure plate.
Before I took the FX300 off it held solid and was smooth as could be when engaging it as in it's not warped at all.
I am going to take input from you guys and make a descision as to whether or not use the FX pressure plate + LUK oem disc or pick up a GMPP pressure plate + GMPP disc.
My car is a daily driver that might goto the track once or twice a year. Streetability is #1 for me.
Anybody who's got experience with aftermarket pressure plate + oem style disc if you could let me know how that worked for you I would greatly appreciate it.
THanks for any input in advance!
Cobalt_noob
Jan 15, 2016 11:34 AM
firehawk618
Nov 15, 2015 07:39 PM
firehawk618
Nov 11, 2015 12:52 PM
firehawk618
Nov 6, 2015 12:54 PM
ATOMbomb
Nov 3, 2015 02:05 PM
