Clutch issues... fix TBD....
Old Jun 3, 2006 | 10:46 AM
SS_SC_Cobalt's Avatar
Originally Posted by 2K5SS/SC?
I measured the difference between the stock pressure plate and Clutchmasters one and there is approximately 1/4" difference between the two. The pressure plate is a different design to create more clamping force, so it will be different. My inner casting could be off too causing a lack of clearance, or I could have an oddball pressure plate that slipped through the cracks by accident. I'll get it figured out one way or another.
PM me the exact measurement of the cm pressure plate and I will compare it to mine that will tell yo if you got a one off..do you have the g85?
Old Jun 3, 2006 | 10:48 AM
distillion's Avatar
so what about eveyone else that has installed this clutch????
are they runnin into issues??
Old Jun 3, 2006 | 10:56 AM
bogout's Avatar
Old Jun 5, 2006 | 07:14 PM
2K5SS/SC?'s Avatar
Great News! Clutchmasters redesigned the pressure plate, and they're sneding me a whole new clutch kit! On top of that they are overnighting it to me, and paying for the old one to be returned! They definately have great customer service!
Old Jun 5, 2006 | 08:23 PM
now the big question is when did they redesign it and do we have the new or old?
2k5, pm me the email or phone number you were dealing with I need to confirm so I can use this one or not, thanks!
Old Jun 6, 2006 | 11:06 AM
soccer1061287's Avatar
I was the first one to install the FX300. They used me to test out the proto. When I first installed it, there was a noise, but it went away. (wore enough bell housing to quit making noise?). Also, my shift efforts have been very high since I installed this clutch. Working the hell out of my synchronizers in the trans. I thought that I had hydraulic problems, cause it would be better in the morning then get worse. PM me with contact name and number of who you have been dealing with at clutchmasters. I do have installation pics if you need them still.
Old Jun 10, 2006 | 01:28 AM
fWdCoBaLt's Avatar
so ya my stock clutch is fried i think as of tonight. so should i order a clutchmasters and which one? i think im stopping at stage 2, header, intake, catback. Also should i get a light weight flywheel and from who?
Old Jun 10, 2006 | 01:36 AM
Floridas Finest SS's Avatar
Well I know that i've recently had the CM fx-300 installed and its not right at all, It is extremely difficult to shift and i have to turn the car off to get it in reverse, i'm about to have it taken out and sent to CM I called and they told me to vacuum bleed it and i did and it still won't disengage so they told us to send it back and they'd look at it.
Old Jun 10, 2006 | 02:26 PM
CobaltSS313's Avatar
Yah same here i have a fx400 and its not releasing all the way and i have to force it to go in gear, i bled the lines repeatedly andit still dont work. i can get mine in reverse but i have to stand on the pedal to get it to do so. WTF is going on im so pissed.
Old Jun 10, 2006 | 02:40 PM
I tried to call the clutchmasters phone number and it says i have to have some kind of access code does anyone have it?
Old Jun 10, 2006 | 02:55 PM
  #36
i jsut sent and email to clutchmasters stating that someone on this site had the same problem and that they redesigned the presure plate are overnighting an entire new clutch kit to them(2K5SS/SC?) and they are paying to have the old one returned. I told them that i m tearing apart my tranny and taking the clutch and pressure plate off and that i expect to have the redsigned kit within a couple of days. So i expect them to send me a new one.
My dad is so pissed right now he said hes calling clutch masters on monday and telling them he wants reimbursed for and the trouble we went through cause we changed my tranny in the driveway with jackstands and a floor jack cause my dad is ASE certified and has been a mechanic at goodyear for 20 years so anyone who thinks that we are 2 average joes were not, he knows what he is doing and it didnt exactley take 10 minutes it actually took 2 and a half days and that if they dont then he is gonna post all over the web that their clutchs are garbarge and not to have anyone buy them, its hilarious hes so f-ing mad right now and for once its not cause of me
Old Jun 10, 2006 | 04:04 PM
  #37
i just got off the phone with CM and they said the only ones that are rubbing are the ones with the transmission with the G85. They said that you have to vaccum bleed the system, which i did several times but they tell you to pump the clutch when bleeding the system where GM tells you not to. So idk ill go see if i can get this damn thing to work.
Old Jun 10, 2006 | 08:04 PM
  #38
djt81185's Avatar
same problems with my fx400 6 puck we manual bled and vacuum bled pumping and not...basically never seen so little air in a system.
The pedal engages on the floor and it grind if I try and shift real high. I honestly think the plastic hydraulic lines are flexing and not allowing us enough fluid travel to completely disengage. I'm going to look into getting some lines made.
Dan
Old Aug 30, 2006 | 08:01 PM
  #39
MVP's Avatar
MVP
what kind of noise did it make because im having some nois issues saturn already replace my whole tranny. its still making noise. I have the fx 300
Old Sep 6, 2006 | 11:57 PM
  #40
fstdude's Avatar
The grove is in a bad place, it is between the pinion and ring gear portion of the cases, This is the most stressed part of the gearbox and is where you can't afford to sacrifice any regidity.
See my earlier pics in post about pinion gear failures.
Old Sep 7, 2006 | 06:36 PM
  #41
phlash's Avatar
i have the FX300 in my car and its hard to get in and out of gear as well, in fact i dropped it off at the dealer to have them fix it this morning...i thoght it was perhaps the shifter assembly itself or something.....its a very "notchy" feeling, unlike my GF's 6spd tib. can someone tell me how to "vaccum bleed" the system? maybe I bled it wrong?
Old Sep 11, 2006 | 11:26 PM
  #42
phlash's Avatar
bump for answer?
Old Nov 7, 2006 | 10:32 PM
  #43
phlash's Avatar
bump for an answer
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
