Clutch is really high
Old Jan 20, 2016 | 10:42 AM
Cwjohnson1995's Avatar
Recently I've gotten a new clutch installed in my 2006 cobalt ss/sc. Since it's gotten fixed the clutch engages at the very top, it couldn't be any higher. At times it feels the gear is slipping. The shop that fixed it says they removed all the air in the lines and they can't adjust the " sweet spot" any ideas on how I can fix this issue? Thanks
Old Jan 20, 2016 | 11:16 AM
exninja's Avatar
Is it definitely slipping?
Could it just be that the engagement is back to where it should be?
Old Jan 20, 2016 | 11:17 AM
blueLNFftw's Avatar
They are normally pretty high.
Is this a KY clutch?
Old Jan 20, 2016 | 01:03 PM
Originally the clutch was perfect when I bought it but ever since the replacement its way to high for engaging, they installed a luk clutch. I'm starting to think it might have something to do with the master cylinder because I'm losing small amounts of brake fluid.
Old Jan 20, 2016 | 01:21 PM
double clutch's Avatar
Crawl under and see if there is fluid leaking at the bellhousing
Old Jan 20, 2016 | 01:25 PM
I already had someone else check it out and they couldn't find leaks so maybe it's internal?
Old Jan 26, 2016 | 12:41 AM
firehawk618's Avatar
Fluid leaking is NOT going to make your engagement point high. It will make it low.
Jan 10, 2016 10:46 PM
suprafanatic26
Jan 5, 2016 08:09 AM
QuickSilver_SS
Jan 3, 2016 01:12 PM
T-fog
Dec 30, 2015 04:55 AM
Coupe DeCobalt
Dec 28, 2015 05:49 AM
