clutch or tranny issue?
Old Nov 17, 2012 | 06:37 PM
royalmc's Avatar
Exclamation clutch or tranny issue?
so i drove to the mall today, clutch slipped once. first time though. went to leave the mall and car starts but wont go into to gear at all.... wondering if any one knows whats up. when it finall grinded into reverse it jumped like i dropped the clutch and died. when trying to start in gear it just jumps like im not even holding the clutch. any ideas?
Old Nov 17, 2012 | 06:53 PM
TurboTechRacing's Avatar
Sounds like just as you stated, disc isn't disengaging. Possible bad slave cylinder unit?
Old Nov 17, 2012 | 07:37 PM
cranemaster's Avatar
Orrrrr... The roll pin on your tranny that breaks / can be half broken until it fully breaks
Old Nov 17, 2012 | 08:39 PM
royalmc's Avatar
ok will look in to it in the morning. just needed some brainstorming. havnt owned my ss for very long
Old Nov 17, 2012 | 09:04 PM
prevsrt4owner's Avatar
What rhymes with roll and pin?
Old Nov 17, 2012 | 09:46 PM
brian.olsson's Avatar
how does your clutch pedal feel, does it feel softer or harder, or feel like its catching anywhere while you push it in
Old Nov 17, 2012 | 09:56 PM
blueLNFftw's Avatar
Why do people not include the sub model of their cars and the mileage when they ask for help?
Old Nov 18, 2012 | 11:45 AM
royalmc's Avatar
well its 2005 cobalt ss sc just hit 120k miles. how hard is roll pin to replace? pedal feels soft, no catching.
Old Nov 18, 2012 | 01:29 PM
As in.softer than before you started having problems,
Old Nov 18, 2012 | 01:53 PM
royalmc's Avatar
feels like it just goes to the floor like not engaging
Old Nov 18, 2012 | 02:44 PM
Check your fluid level, its the same one as the brake fluid, than check the clutch line from your master cylinder to.the slave cylinder and make sure its not leaking and the connections are tight and the clips are in, than bleed the clutch out cause you might have gotten air in the line, if its still not back to normal, pull the master and check that it works properly, if its not, replace it, and if your still haveing issues, check the slave cylinder, also called the throw out bearing, only to do that, you need to pull the tranny out, let me know
Old Nov 18, 2012 | 02:50 PM
You guys are idiots, the guy even said he hasn't had his car that long, and their are more than.one roll pins on the tranny, I've tore these cars apart a couple times, and I.can't even think of where this rollpin your talking about is, instead of jumping to things like that, maybe you should ask more questions about the issue he's having, did you even think to ask how the clutch pedal felt,
Old Nov 27, 2012 | 07:43 PM
royalmc's Avatar
fluid is good. it was one of first things i checked when happened. will have to check lines. havent had time with work duty and holiday
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
