Cluth making a grinding noise
Old Sep 12, 2012 | 01:17 PM
Manopka's Avatar
Im not 100% sure its the clutch. but heres the symptoms: when I'm driving at 35 mph or more and I release the gas but im STILL in gear, i hear the noise. the noise stops if i press the clutch in but once i release it the noise starts again. the noise does not occur whatsoever if the car is in neutral.
Ive done google research and everyone gives different responses but a common one is an aftermarket clutch or a lightened flywheel.
what do you guys think?
Posted from Cobaltss.net App for Android
Old Sep 12, 2012 | 01:19 PM
bluebalt07's Avatar
Post a video of the noise if you can hear it on a video. Mine makes noise also but it seems to just be widely accepted that aftermarket clutches on cobalts all make noise.
Old Sep 12, 2012 | 05:10 PM
sportcarmn's Avatar
do you have a lightweight flywheel? if so it can cause some very loud vibration/grind like noises. My stock clutch/flywheel was very quiet. After i switched to an ACT unsprung 6puck and streetlight flywheel it sounds like my transmission is eating itself when not accelerating and in gear(noise when decellerating*). Stock flywheel dampens quite a bit, i wish i had never switched mine
Last edited by sportcarmn; Sep 12, 2012 at 05:14 PM. Reason: noise when decellerating*
Old Sep 13, 2012 | 09:46 AM
Gelladuga69's Avatar
Exactly. I have the GM11-HDSS from ACT and it's like a damn lion is in the transmission growling at you to keep your foot on the gas.
I don't know what the stock/GMPP clutch sounds like or if it makes any noise at all. I've only had ACT clutches when I bought the car.
06MetallicBalt
Jul 20, 2025 08:47 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
jimbofug007
Oct 2, 2015 12:06 PM
Stuff
Oct 1, 2015 05:47 PM
