:cussing: clutch help
ok so i just put my motor back in and bleed the clutch from the bleeder started the car back the car up moved fine and took it down the road took it up to 2gs and shift it in to 2 and than when i pushed the clutch in and put it in first it went in to first but did not move at all. i can still hit all the gears but the clutch like bearly grabs it seems like i bleed the brakes and the are hard as a rock im out of ideas and the clutch is a spec stage 3 so some one please help
no becasue when i pulled the motor out the trans only had 35k so i though it would be ok so you think that might be it
do you think if the trans fluid is low that would make a diff to be casue i did lose some when we pulled the motor
Last edited by blacksssc06; Jun 10, 2008 at 06:42 AM. Reason: Automerged Doublepost
Re-bleed the Clutch. That is your problem... and that will also the the pain in your ass.
Its a two person job... and it takes some perfecting.
Trans Fluid will have no effect on it... and you don't need to replace the slave cylinder... but you need to be sure that you put that black ring back on top of the slave cylinder.
yeah the rings there and i dont think it the slave casue it would have quiet when i backed up and drove a little and we bleed that thing for like a hafe hour and it sounds lke there still air coming out but the clutch pedal is stiff
also when we had it on stands i let the clutch out and it turns the wheels but barily so you think there just more air or what
Last edited by blacksssc06; Jun 10, 2008 at 06:53 AM. Reason: Automerged Doublepost
I dunno... when I did mine, I was on stock clutch. And I only had to bleed it for like 5 minutes.
Open the bleeder... and have someone pump the clutch pedal until fluid comes out in a steady flow... then have them push in the clutch pedal and while the pedal is pushed in, you need to close the bleeder.
its wierd when we were bleeding it like after the bleeder was closed and the pedal had a crapy feel the first to pumps than it stiffend up i dont know
i need to find that vacum pump they tell you to use maybe that well help
Last edited by blacksssc06; Jun 10, 2008 at 07:03 AM. Reason: Automerged Doublepost
I didn't use the Vacuum Pump and mine feels just like it did before. You don't need it.
And yeah, my pedal felt empty at first... then I had to re-seat the Slave Cyl and it started building pressure after that.
I had to take it off the Transmission and put it back on... for some reason it wasn't seated properly and therefore didn't have a good seal.
i'm talking about this... sorry for confusion...
Last edited by USMCFieldMP; Jun 10, 2008 at 07:36 AM. Reason: Automerged Doublepost
First off, as I've stated a million times before on here always replace the slave cylinder anytime the clutch is removed! Most likely you are going to have to pull the transmission now and replace it.
Secondly, do not use the vacuum bleed method as it usually messes up the slave cylinder. The old two man procedure is best unless you have a speed bleeder then you can do it by yourself.
Finally, check the clutch line fitting/o-ring that goes into the distribution block on the trans. Ensure it is in good shape and sealed properly.
cars good that what it was a bad slave good call everyone thanks
i would put that has a sticky that you need to do the slave if you do a clutch
Last edited by blacksssc06; Jun 12, 2008 at 09:00 AM. Reason: Automerged Doublepost
I've screamed till I was loud in the face on this one, but the mods never listen!
I might make a thread one of these days and hopefully the mods will listen!
Glad to see you worked it out though!
