Dealership replacing clutch....quick question need help!!
Old Jun 11, 2009 | 09:21 AM
MikeyMo84's Avatar
i had GM do some warranty work on the synchros in my trans and while they had it off i figured id have them change out the clutch too...spoke with the dealership this morning and asked them to make sure to cut the flywheel and he said hed get back to me on whether or not that was even possible....
whats the deal here?? can/should the flywheel be cut?? its an exedy stage 1 clutch if that makes any difference
Old Jun 11, 2009 | 09:26 AM
Bika's Avatar
Fail Less.
by cut do you mean resurfaced / turned down? if so, Yes it should be easy for them to do. just like turning down a brake rotor.
Old Jun 11, 2009 | 09:38 AM
Chuck's Avatar
it normal to have a flywheel resurfaced.. Infact anytime you put a new clutch kit in you should resurface the flywheel or replace if its to bad..You what it resurfaced because the clutch disc is sandwiched between the flywheel and the pressure plate. your pressure plate is new and perfectly even, so you need to have the flywheel resurfaced so its close to perfectly even and there are no dips or hotspots.. Doing this keep the clutch disc from chattering and makes for a smooth engage..
Old Jun 11, 2009 | 10:29 AM
MikeyMo84's Avatar
thats exactly what i thought lol but when i called the dealer this morning and the guy said that the tech was gonna let me know once he took the whole thing apart whether or not it could be cut so if they say they cant when they call back what should i do??
Old Jun 11, 2009 | 10:37 AM
PRND3L's Avatar
well you have to inspect it first, if it has cracks or severe hot spots you cant machine it and it would need to be replaced. Also, most dealers dont have the ability to machine flywheels and they get sent to a local machine shop to have that done.
Old Jul 25, 2009 | 10:09 AM
redline4's Avatar
How did you get your clutch replaced under warranty? Also my dealership said I had to buy a new flywheel for my car since I couldn't put an aftermarket clutch on the stock flywheel...is this true?
Old Jul 25, 2009 | 10:07 PM
qwikredline's Avatar
no but exedy hypersingle comes with a (lighter) flywheel
brandon04
Oct 21, 2015 07:04 AM
justinchinn
Oct 2, 2015 12:18 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Slick_Nick
Sep 28, 2015 09:15 PM
reybalt
Sep 27, 2015 07:57 PM
