Do I have LSD?
Old Nov 2, 2010 | 09:22 PM
H3 Proto's Avatar
Do I have LSD?
I have a 2007 SS/SC. The internet has confused me. Wikipedia (an unreliable source) says that it came standard in the SS/SC in 2006+. I thought it was only if you got the package with Recaros. And I don't see LSD anywhere on my sticker.
Old Nov 2, 2010 | 09:27 PM
Chevycobaltss3's Avatar
If u bought t new it'll say lsd equipped. Or u can look on.the tranny itself. On top. Y the fuse box. Or you can look it the back of the car underneath the. Mat.
Old Nov 2, 2010 | 09:28 PM
TurboTechRacing's Avatar
Yup window sticker will state "G85" code, which means LSD
Old Nov 2, 2010 | 09:32 PM
H3 Proto's Avatar
Wikipedia says mine should come with it standard. Is wikipedia wrong again?
I bought it used but it has the original sticker. And I would have no idea to look on the car for it..lol.
Old Nov 2, 2010 | 09:34 PM
mexi_loco's Avatar
yes...wikipedia is wrong. Look in your trunk. There should be a serial code stamped in the body somewhere back there. The code is the serial number is g85, which means you have lsd.
Old Nov 3, 2010 | 12:05 AM
Erick161's Avatar
What he said. Pick up the carpeting...on the drivers side is a silver piece of metal stamping, shows all the options the car has. OR you could run your VIN
Old Nov 9, 2010 | 08:44 PM
myoshizawa819's Avatar
Or you can look for the plate on top of your transmission. It's visible looking from above in the engine compartment and it will clearly say "LSD" on it if your's is equipped. ...there are also the tell-tale Recaro seats lol. If your seats have Recaro stitched in to them then your trans probably has limited slip unless it was replaced with a non LSD unit at some point.
Old Nov 9, 2010 | 08:47 PM
thedude411's Avatar
07's came without recaros
Old Nov 10, 2010 | 03:38 PM
H3 Proto's Avatar
Thanks everyone. I've established the fact that I do not have LSD.
Old Nov 10, 2010 | 03:40 PM
Nacademus's Avatar
Its not the end of the world.
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
HEATON
Oct 16, 2015 07:21 PM
bigdogstokes16
Oct 8, 2015 10:28 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
importkiller
Sep 30, 2015 07:18 PM
