droning rubbing sound while driving
Old Oct 18, 2014 | 09:49 PM
Dombant's Avatar
when i drive my 05 ss when ever i drive and let go of the gas the car makes a wierd sound that is very loud almost sounds like grinding but not quite it also makes the same sound when im on the highway at a constant speed my car got 156k on it with the original clutch it makes the a less intense sound when i and rolling at a faster speed but its louder with clutch engaged i thinking its jus cause the clutch on it way any thoughts or wheel bearing it also makes this loud thump sound when i go over bumps
Old Oct 26, 2014 | 08:03 PM
SS Gordon's Avatar
The thumping noise is most likely the stabilizer bushings or the connecting arms I just replaced both and my noise over bumps is gone.
As far as the grinding it sounds like a wheel bearing but it's hard to tell, jack it up and spin each front wheel & see if you can feel a grind or noise, also shake the wheel while you have it jacked up to see if there is play in the bearing?
I have 05 also & I replaced both front bearings at about 90,000 miles mine made a humming noise and got worse the faster I went.
Is it on the drivers side or passenger side or can you tell with the windows down?
Look at your CV boots & make sure it's not a CV joint?
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
