Dumb Question
Old Mar 25, 2010 | 10:24 PM
RYRO14's Avatar
Dumb Question
http://www.modernperformance.com/clu...lt-p-1895.html
Is Slave Cylinder just another name for a throwout bearing? Or are they to different parts all together?
Old Mar 25, 2010 | 10:26 PM
mexi_loco's Avatar
no it's not. But the slave cylinder is a unit and the throwout bearing is part of the assembly. So essentially if what you're asking is if the slave cylinder is all you need, then yes it is.
Old Mar 25, 2010 | 10:30 PM
RYRO14's Avatar
So the clutchmasters clutch on modernperformance doesnt come with the slave cylinder, only the throwout bearing?
Old Mar 26, 2010 | 08:31 AM
mexi_loco's Avatar
the throwout bearing is part of the slave cylinder assembly. When you swap clutches, you have to swap out the whole slave cylinder assembly.
Old Mar 26, 2010 | 01:31 PM
Iam Broke's Avatar
The slave cyl & throwout bearing are one part number, it's a unit. I listed the GM P/N in my clutch thread in the LNF performance tech section. I replaced it when the clutch was put in. Do the ZZP clutch rod at the same time.
I thought you already did a clutch, no?
Old Mar 26, 2010 | 02:03 PM
cmiller8006's Avatar
I just got the clutchmasters setup and it came with the throwout, and thats all you need. But like iambroke said get the zzp clutch rod. I dont have my clutch installed yet so cant tell you anything.
Old Mar 26, 2010 | 03:15 PM
RYRO14's Avatar
No not yet, just trying to figure out what I need first
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
