Dumb Question
Dumb Question
http://www.modernperformance.com/clu...lt-p-1895.html
Is Slave Cylinder just another name for a throwout bearing? Or are they to different parts all together?
no it's not. But the slave cylinder is a unit and the throwout bearing is part of the assembly. So essentially if what you're asking is if the slave cylinder is all you need, then yes it is.
The slave cyl & throwout bearing are one part number, it's a unit. I listed the GM P/N in my clutch thread in the LNF performance tech section. I replaced it when the clutch was put in. Do the ZZP clutch rod at the same time.
I thought you already did a clutch, no?
I just got the clutchmasters setup and it came with the throwout, and thats all you need. But like iambroke said get the zzp clutch rod. I dont have my clutch installed yet so cant tell you anything.
No not yet, just trying to figure out what I need first
Iceberg
Sep 29, 2015 12:33 PM
