Engine support for transmission removal
Old Mar 7, 2013 | 07:55 PM
bcuree's Avatar
I must be over looking it, but I can't seem to find the hook location on the engine to attach the engine support. If anyone can give some info on where it is or what I need I would appreciate it. Thanks in advance
Old Mar 7, 2013 | 07:56 PM
574's Avatar
574
On your head there should be two black brackets that stick up. Or you can support the oil pan but make sure you have something between the jack and pan
Old Mar 7, 2013 | 08:04 PM
bcuree's Avatar
Ill look again when I get home. Thanks
Old Mar 7, 2013 | 09:45 PM
Sharkey's Avatar
our cars dont require an engine hanger. the engine and trans both have mounts bolting them to the body, so remove the subframe from the car, support the transmission and remove the transmission mount, and before removing the bellhousing bolts support the engine. best to use a jack or jackstand, just dont forget to use a block of wood between the support and the oil pan to avoid breaking it.
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
