f23 fail
maven, from what i have read you know your ****. ill admit to the f23 not being as bad as i had thought. but does lsd reduce stress on the trans or not? blazin said it doesnt u say the f23 needs one to be a good trans. also my cobalt only has 152 ft-lbs but my 4t45 is rated at 325, not to argue tho i just found it odd that you said that. i still stand that a stock f23 CANNOT handle 700hp and 500 ft-lbs down the track multiple times with slicks and hard launches. how much power did your ls make with your f23?
you are confusing what i said. i just said it doesn't make it stronger. the damage he is talking about it doing 1 wheel wonders. remember when there is only one tire spinning, the diff is spinning at twice the speed causing a crap ton of heat. even though i am open diff i always spun both tires at the track. even when i felt it going to one wheel. i would let off
Wo|F
Sep 28, 2006 11:29 PM
