F40 install
Old Mar 10, 2014 | 11:27 PM
shobalt87's Avatar
Angry F40 install
Any F40 swapped guys out there? I bought the trans and kit but have ZERO instructions. I dont know if ZZP forgot to include them in the box or not. Also my box wasn't taped properly and a bolt fell out onto the floor so lord only knows if I have all the right stuff. Really could use the help, pretty sure ZZP has black listed me and stopped answering my emails.
Old Mar 10, 2014 | 11:30 PM
sl0wlsj's Avatar
Bug them! You paid enough for that kit, get instructions and info you need. Also, check on their website..sometimes they have the instructions in the additional information tab on the products page.
Old Mar 11, 2014 | 01:46 AM
kzak104's Avatar
looking at whats included in their kit it looks pretty straight forward. remove parts put replacement parts on.
or are you asking for instructions to remove the tranny?
Old Mar 11, 2014 | 10:45 AM
paintballerr78's Avatar
they are moving shops thats why they arent answering emails not cause your blacklisted. Myself and a friend emailed them 2-3 days ago and still havent heart anything your gonna have to give it time. I know Infraredline installed a f40 into his redline maybe he can give some pointers
Old Mar 11, 2014 | 10:57 AM
yellowsupercharged06's Avatar
for the amount of $$ that kit is, i would expect instructions that would explain it enough to make it possible for a blind man to install the trans.
Old Mar 11, 2014 | 11:16 AM
InfraRedline's Avatar
As Paintballerr said, they have been busy moving. Tim and I email back and forth once in a while and he usually replies really quick and this time it has been about a day and a half, which considering they are settling in, is just fine. How long has it been since you emailed someone? If its been a long time then I can see the concern.
I installed the F40 in my car, and it was really straightforward. Pretty self explanatory where everything goes. Follow the GM build book as if you were changing the clutch on the F35. The mounts and axles and things for the F40 only work one way so you cant really put anything in the wrong spot. Then you know where the shifter and the cables go. Just dive in and it will be completed before you know it.
Old Mar 12, 2014 | 08:16 AM
shobalt87's Avatar
Ive got the old trans and motor out of the car, its all the new brackets that are unlabeled and im not sure which bolts need to come off the F40 to mount the new brackets
Old Mar 12, 2014 | 09:34 AM
shobalt87's Avatar
Ive been exchanging emails with Jason so it looks like ill be resolving the issue soon. I took inventory of what I had and he's sending me stuff im missing. Still no pictures of brackets installed though. If you have any pictures you could post or email me, it would be a big help. I also understand cmiller has done it but I dont know him. Im confident turning wrenches but I dont know what bolts/brackets go where
Old Mar 12, 2014 | 12:17 PM
I didn't really take any pics during the install, and you can't really see much now that its all together. The "ZZP" engraved bracket goes on the top of the trans to mount into the new one that you put into the frame, and the more L shaped bracket goes on the back of the trans and the factory rear trans mount bracket bolts to it.
Old Mar 12, 2014 | 03:29 PM
m33pm33p's Avatar
For the amount of mechanical ability it takes you should be able to do it without instructions. There are only so many parts to the kit and they can only go one way.
Old Mar 12, 2014 | 04:07 PM
Powell Race Parts's Avatar
i think a picture is worth a thousand words. I did not have time when i was there, but if you can find someone who was at the CED meet this summer, maybe that someone took pictures of the F40 conversion that ZZP had on display , get those pictures, and you are set. Pretty much.
Old Mar 16, 2014 | 11:30 PM
shobalt87's Avatar
got the kit installed, Jason@ZZP was a big help, he sent me some pictures of a motor/trans combo sitting in the shop. Only thing I didnt find out was if the cable bracket required me to remove 2 bolts on the top of the diff, install the bracket, then replace the bolts to tighten them down OR put the bracket over the extended portion of the existing bolts and find some nuts to secure the bracket. I did the first option and everything seems to line up. I hope with this new setup I wont be investing in any more shifter cables. **also modified my Hurst Short Throw to work with the new 6spd bracket **
Old Mar 17, 2014 | 12:46 AM
WSFrazier's Avatar
Did you guys just pay 1500 for an F40 from ZZP or source them out?
Old Mar 17, 2014 | 10:15 AM
I just paid for one from them. Checked our local salvage yards and they had nothing, so I said good enough and got one from ZZP. Comes with a year warranty that way too, so I didn't mind. After putting some driving miles on I am absolutely sold on this transmission. Everything is just so smooth and effortless. The whole driving experience has changed...and I'm sure the turbo has nothing to do with that fact
Old Mar 18, 2014 | 11:55 PM
WSFrazier's Avatar
I assume you guys went with the lighter flywheel and 6 puck? I'd like the 6 puck disc, but not sure if I'd want the lighter flywheel for drag racing.
Old Mar 20, 2014 | 11:14 AM
I went with the regular dual mass flywheel and full face clutch. Starting to 2nd guess my decision on that just because I am not sure it will hold my power goals of 600whp, mainly because it is still pretty new so not many guys have ran them yet to see what it will hold. Feels great driving around town and hasnt had a problem holding ~450-475whp so far, but it is still new and the boost isn't cranked yet.
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
ashalle2
Sep 27, 2015 03:28 PM
